Question about Bladez X350P Elliptical
How do you set it to manual no program - Bladez X350P Elliptical
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
Mar 06, 2015 | UPM Hardware & Accessories
Understand the instructions for TS EE8
Following link has product manual that might match your timer:
Use + button at top of manual to enlarge print.
http://waterheatertimer.org/pdf/Argos-7day-Electronic-Timer-Manual-TS-EE8.pdf
Please add a comment and say if this manual matches your timer...fixya will send me email... and I will answer.
Include where you get confused.
You set current time first... that's the time that shows on your wristwatch right now.
You set day of the week... same day it is right now.
You set hour and minute.
The timer allows you to set up to 8 programs... you can set just 1 program or 2 or 3 etc.
Each program must have ON time
You set program 1 ON
Each program must have OFF time.
You set program 1 OFF
Each program must have a day or days of operation
So you might select monday ON at 10:10 am and OFF at 3:36 pm.
And other program for Tuesday ON at 10:45 and OFF at 4:00 pm.
When programming is finished, you set mode to auto for programs to run on the schedule you set.
Gene
Feb 28, 2015 | Hardware & Accessories
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
I have a ET100C and the lights will only stay on for a few seconds in both manual and auto modes
Before you attempt any reprogramming, you might be better served by performing a RESET on the clock. TO RESET TIME SWITCH COMPLETELY: Press the recessed RESET switch for five seconds to remove all eight available events and to reset time of day clock to 12:00 A.M.
After resetting, try reprogramming again. The procedure below is copied from the manual (which can be downloaded here):
TO MANUALLY TURN ON OR OFF: Program Selector switch must be in RUN position. In AUTO or MANUAL Press ON/OFF button. Display indicates load is either on or off.
TO SET TIME: Slide Program Selector switch to TIME SET. Press HOUR and
MINUTE buttons individually to select current time of day. Note that clock is a 12 hour AM/PM repeating clock.
TO SET OR CHANGE PROGRAMMED SET POINTS: Select PROGRAM mode with Program Selector. Note that the event display shows Event #1. There are eight possible programmed events. Four ON and four OFF which are programmed alternately. All available events need not be used.
Press the HOUR and MINUTE buttons separately to program the first ON time
desired. Note the ON indicator (OFF in the next step) will only be displayed after the hour has been selected unless an ON time was previously entered.
Press EVENT button. The display now shows the next Event #2. Press HOUR and MINUTE buttons separately to select first OFF time or Event #2.
Press EVENT button to select Event #3. This is the second ON time. Program the ON time by pressing the HOUR and MINUTE buttons. Repeat this procedure for up to 4 ON and 4 OFF times (8 Events) as required. Return Program Selector switch to RUN Position. Be sure Manual/Auto switch is in the AUTO position.
TO OVERRIDE PROGRAM: Program can be overridden at any time by selecting the MANUAL position. Program set times will be maintained but will not operate the controlled load(s) automatically.
TO CHANGE OR DELETE PROGRAM SET POINTS: Place Program Selector switch into PROGRAM mode. Press EVENT button to step through the eight possible events. Note that the times which have been programmed will be displayed or 0:00 will be displayed if no set point has been entered. To change an event time, press the HOUR and/or MINUTE buttons to change the time currently in the program to the new time desired. Press EVENT button to proceed to next programmed event. To remove a programmed Event: Press the ON/OFF button two times. When this is done, the display will show 0:00 and the event number.
I hope this helps & good luck!
Nov 16, 2011 | Intermatic ET100C Energy Controls -...
Need to know how to program merry brite digital indoor timer?
Merry Bright digital looks same as GE 15057 and Westek TE55WHB timers
To identify your timer see following two links:
http://compare.ebay.com/like/260679690470?
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Add a comment if this is not your timer.
Here is Westek TE55WHB manual.
Read manual for full information.
http://waterheatertimer.org/pdf/WESTEK-TE55WHB-manual.pdf
Here are instructions taken from manual.
To set current time:
Hold down CLK button and then push day hour and min button until current time shows.
To program:
Press PRG button until 1 and ON display.
Press day hour and min button to set program1 ON
Press PRG button until 1 and OFF display.
Press day hour and min button to set program1 OFF
Press PRG button until 2 and ON display.
Repeat steps to set more programs.
Set up to 7 programs
Programs repeat each 24 hours
When finished, press CLK button and current time displays.
To operate timer: press MODE button.
AUTO to run timer functions.
RDM and timer turns on-off at random times.
Manual to override timer functions.
Dec 22, 2010 | Garden
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Having Difficulty programing Woods Brand electrical timer !
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
Download Woods manuals
59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
Do not hold down PROG button
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to finalize ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
Press PROG to advance to program 3 through program 8
Press ON/Off button to exit programming
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Oct 07, 2010 | Woods Industries 59377 Indoor Digital...
I programmed the timer to go on and off at a specific time and it doesn't work. The time of day and the date are working fine. It is only programmed for one light.
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual has troubleshooting. Since ST01C is battery operated, it will not work on loads farther than 100 feet away from timer. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with timer operation.
2) Solution:
a) Check for interference issues listed above.
b) Press MODE and make sure it is set to AUTO. If timer will not enter AUTO then no program has been set.
c) Re-check your programming as shown in step 6 of manual. Remember timer offers 40 programs. To set Program 1 >> 'on' time has to be entered and saved for Program 1 >>> and then 'off' time has to be entered and saved for Program 1. And then press MODE and set to AUTO.
Sep 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Bladez X350P Elliptical Logo
50 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
