Question about Philips Televison & Video
Need green tube.
I had a tech come check the tv and was told the green tube was bad and needed to be refurbished or replaced. where can i find one, i was told that they are not made anymore.
  • Philips Master
  • 19,396 Answers
Have a sony kp-57ws500, tubes are going bad. Should I fix or get new tv. How much are new tubes. Red is out now. How much is one?
This is one of a group of sets with bad tubes, many were replaced under warranty (it seems they actually put the wrong ones in thousands of these sets)
The tubes are no longer available from Sony and only available on a rebuild basis---figure over 350 per tube plus labor.
IF THE SET IS COMING ON RED, GREEN OR BLUE SCREEN, AND OR SHUTS OFF---THERE IS A WAY THAT REQUIRES NO PARTS TO TRY TO ADJUST IT.
Give me a better idea of what the set is or is not doing and I would be happy to advise you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 17, 2010 | Sony KP-57WS500 57" Rear Projection...
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was...
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
Sony tv keeps shutting itself off
HI,
If TV shows high bright light of either red, green or blue and shuts off then it got related color picture tube problem that will be replaced.
Bad picture tube replacement is job of qualified tech because it requires multiple adjustments after replacement. Please check with local tech for an estimate.
Hope this info will help you.
Thanks.
Dec 14, 2009 | Audio Players & Recorders
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I think I have the same TV darker color not as sharp
the fluids do need to be changed occasionally.hes right about that.if you allow him to do it he will clean everything associated with the tubes
Dec 29, 2008 | Philips 60PP9202 60" Rear Projection...
Leaking green tube that needs to be replaced
It wont be worth it, when you change 1, it is strongly sugested you replace all 3, and they cost around 200$ a piece, but just so you know, they cant leak, unless you break the glass at the top
Dec 15, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony kp-57ws500 green screen then auto shutoff
I have the same tv and it did the same thing only now it has red hues all around the picture as well. The service guy told me it was the green tube and it would be about $500.00 to replace and may not fix the problem. What a p.o.s. I will not be guilty of buying any other Sony products from now on.
Jul 20, 2008 | Sony KP-57WS500 57" Rear Projection...
No green on my hitachi 57s715
I would check for loose connection around the yoke and convergence ic's (stk392-xxxx)
Dec 01, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
