Question about Optimus H-5300 Quartz & Convection Radiant Heater
Heater light wont even come on when plugged in optimus quartz 2-in-1 convection and radiant heater
BH 3950 plug overheating
this happens when you have run a heater for a long time on an outlet that is either not giving the heater enough amperage or to much amperage try it in a different room if the problem persists try a different heater.
Nov 05, 2011 | Humidifiers
Hi, I flushed out the round mister after it sat
If you have hard water and theres scale present you will need to clean the heater in the bottom.when you remove the heater the scale will sometimes crumble by just squeezing it although a few times Ive had to use a descaler like CLR and a pick to get it off.
Dec 13, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Aprilair 760 Humidfier will not stop water flow to EV panel
If the water continues runs nonstop even when the heater is turned off, you might have either a bad solenoid valve or a bad humidistat. Simply disconnect one of the two low voltage wires going into the unit. If the water turns off then your problem is most likely your humidistat or the low voltage wiring. If the water continues to run even when the low voltage is disconnected you have a defective solenoid valve.
Good luck.......
Apr 09, 2009 | Aprilaire 700 Humidifier
Appril air 600 wont work
the change water panel light is just a timer. it does not sense that the water panel actually needs to be replaced. sounds like you have a solenoid issue. if you have water to the solenoid and are certain you are getting 24v to it, the solenoid is ethier bad or plugged with calcium. most likely calcium. sometimes you can take them apart and clean them. so, it you can hear clicking at the solenoid when you turn the humidstat up and down. try cleaning it.
Jan 14, 2009 | Aprilaire 600 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Wall heater does not work!
it sounds like the gas valve is not getting power. There is probably a saftey device that has tripped, preventing the voltage (24v) from energizing the gas valve. check for 24v throughout the circuit. It should be a simple series circuit.
Nov 11, 2008 | Honeywell Power Humidifier: Furnace...
Optimus H-5300 Quartz & Convection Radiant Heater Logo
60 people viewed this question
Top Optimus Humidifiers Experts
Mack Baxter
Dennis
Are you an Optimus Humidifier Expert? Answer questions, earn points and help others
