Question about Quicksilver Quiksilver Windy Digital Watch
How to set a date and time on a windy quicksilver digital watch.
How do i change the DATE ( on top right of watch face ) on the QUICKSILVER ACCENT DIGITAL WATCH for men ?
You will need to pull out adjuster and turn to
right or left depending on the date you have on it.
Today 11th so if on 1st turn clockwise until you get
to 11th.
LUCK
Oct 11, 2014 | Watches
I have a new windy watch but dont know how to set the date and time on it could anyone please help me?????
annoyingmist, let me try.
1.by windy you mean mechanical?
2. if yes, then move the hands clockwise watching the calender until new date appears.
3. now turn hands anti- clockwise a little and clockwise again. Keep doing until you get today;s date.
4. set the watch to correct time. good luck.
Dec 25, 2013 | Watches
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Mar 04, 2011 | Timex 1440 Nylon watch
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
Dec 25, 2010 | Timex 1440 Nylon watch
How do you set the time on the timex 440 sports watch
Hi markie_d,
Timex Digital Watch
Hope it helps.
Oct 31, 2010 | Timex 1440 Nylon watch
Would like to learn how to set time on on Timex 1440 sports watch
Hi danielrob676,
Timex Digital Watch
Hope it helps.
May 28, 2010 | Timex 1440 Nylon watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
How do i set the time and date
Hi hernandez415,
Timex Digital Watch
Hope it helps.
Nov 02, 2009 | Timex 1440 Nylon watch
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Quicksilver Quiksilver Windy Digital Watch Logo
77 people viewed this question
Top Quicksilver Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Quicksilver Watch Expert? Answer questions, earn points and help others
