Question about Toshiba D-R400
Toshiba D-R400 shutdown - Toshiba D-R400
I have no sound through my tv, when watching through the D-r400. This has not been a problem prior. If I watch through my TIVO, sound is good, but when I switch to the DVD recorder, I have picture, but...
have you tried any of the internal audio option within the players on screen menu's perhaps it got switched to a digital output in there somehow instead of the hdmi your needing to use
Dec 19, 2010 | Toshiba D-R400
My TABLET PC PEN is not working. suddenly its stopped. i dont know why. is it contained battery ? if yes where to find. please help me.
hi no this does not have a battery, this sounds more like a software problem, or your touch screen may be faulty or both, try installing the drivers for the screen again if not this will be a Toshiba techs job..hope this helps
Aug 02, 2010 | Toshiba DIGITAL TABLET PC PEN FOR PORTEGE...
Won't eject disc
It is a common problem with all DVD players and writers. the belt become loose therefore it does not eject. replace a belt with new one.
will work. Good Luck
Nov 25, 2009 | Toshiba D-R400
Cant eject dvd after my daughter inserted into our toshiba d-r400. It won't play either. is there a way to manually remove it from the player
you need to take the top off (after you unplug it), and you should be able to see the carriage from the top. if the top of the carriage doesn't come off easily (2-4 screws or clips) to remove the **** that way, you'll need to take the whole carriage out. there are only a few screws but there are ribbon cables and wires attached, so be careful not to pull any too hard. remove the wires and cables, the few screws, and take the carriage out. you should be able to easily take it apart from there and remove the ****. but remember what screws go where.
Jul 15, 2009 | Toshiba D-R400
Toshiba d-r400 recording
I don't see anywhere in the program menu to input a channel number to be recorded, only date and time.
May 03, 2009 | Toshiba D-R400
How do I finalize a disc on my Toshiba D-R 400
Go to SETUP on your remote, scroll down to DVD Menu, Select Finalize and confirm.
Aug 06, 2008 | Toshiba D-R400
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Open Questions:
Toshiba D-R400 Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
