Question about Motion Computing LE Tablets & eReaders
Motion computer battery - LE Motion Computing Tablets & eReaders
    Problem Solver:
  • 9 Answers
If you want your problem solved then you should provide a detailed account of what is going on with the device.
Posted on Nov 24, 2014
Show me how to restore my tablet to factory settings?
Hi Anonymous.
Looking about, the manual for this system
https://www.motioncomputing.com/downloads/User_Docs/LE1700/LE1700UserGuide_vista.pdf does not talk about how to reset the system. There is mention of a reset for a CL900 system by pressing the SAS, Battery Status, and Power buttons at the same time
http://support.motioncomputing.com/kb/KnowledgebaseArticle10597.aspx?Keywords=LE1700+Reset I can't verify this will work on the 1700.
Your most direct answer may come from calling the Motion Computing technical help line:
1-866-322-9783, option 9.
7am-8pm M-F CST
Good Luck!
D
Nov 23, 2015 | Motion Computing LE Tablets & eReaders
Motion LE1700 Tablet PC repair
If the tablet is turning on, but not booting into your os then there is most likely a problem with the hard drive. If the computer doesn't turn on at all then the battery or charger may not work.
Apr 02, 2013 | Motion Computing LE1700 Tablet PC
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
My motion computing battery light is not on and the machine won't start
Hold down the power button for 10 seconds then release. Then try pressing the power button again.
Apr 26, 2011 | Motion Computing J3400 Rugged Tablet PC...
I was given one of these tablet pc,s and I do not have the Bios Password is there a way to bypass the bios password?
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Jan 21, 2011 | Motion Computing M1300 Tablet PC
It won't charge anymore, when it's on it just doesnt say that it's charging, but the light on the charger is on. When it's off, the orange light for charging is on, but it still doesnt charge anyway. I...
The computers contact point for the charging cord is "VERY" sensitive for me. I had to try many times to actually see the charging "icon" light up before letting it charge. Many times the icon would go back to "battery" during charge and I would have to re-try the connection again... Very annoying. If the battery get so drained that you can't see the "charging" icon, then it's a guessing game as to whether it's charging or not. I needed to re-install the OS and it took me 3 days to get my battery charged that way.
Aug 25, 2010 | Motion Computing M1400 Tablet PC
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Pin does not work when touched to screen.
The stylus has a AAAA (yes, QUAD-A) battery in the body of the stylus - if this is dead, then the digitizer won't recognize the pen. That sounds like what is happening - the batteries can be found at bigger Radio Shacks or ordered online.
Oct 22, 2009 | Motion Computing LE1600 Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Tablets & eReaders Logo
Top Motion Computing Tablets & eReaders Experts
k24674
Andrew Taylor
Andrew Taylor
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
