Question about Garden
Poulan troubleshooting I have a brand new poulan pro 208cc snowblower that I cannot get started. Gas tank is topped off - not sure if I am doing the starting process in then wrong order??? The electric start is turning the however it isn't turning over. Help please as about to get hit with 8-12" of snow tonight.
  • 9 Answers
SOURCE: poulan pro 260
Clearance from coil to flywheel should be around .010
Posted on Oct 26, 2008
SOURCE: Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Posted on Dec 31, 2008
  • 473 Answers
SOURCE: snapper electric start snow thrower won't start
If the engine has a float type carburetor, remove the float cover and see if the float is hung in the down position. If so free it up and make sure it will now operate freely up and down. If not and the bowl is full of crud, you will have to remove and clean the carb.
Posted on Mar 13, 2009
slohry
  • 87 Answers
SOURCE: Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Posted on Apr 09, 2009
Fog Horn
  • 17 Answers
SOURCE: Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
Not used in 10 years. Was there gas left in the tank? If so the carb is likely gummed up and may need to be taken apart and soaked in "Gunk" solvent and a new kit installed.
Posted on May 26, 2009
My Poulan Pro Snowblower not breath as the first year that would be the problem.
The first thing to do is drain out any old gas and put in new gas and try starting
Dec 07, 2014 | Poulan Garden
Poulan pro troubleshooting
Try changing the fuel filter in the tank.
Jul 12, 2014 | Poulan/Weed Eater PP030 966805501 Poulan...
Stalling
drain gas from carb and tank get some fresh non ethynol gas
while carb bowl is off spray/ clean with carb cleaner spray.
when you drain gas put it in clear container so you can see if there was water or dirt in it. helps to figure out the problem
Mar 27, 2014 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Starting poulan pro snowblower
gas spark and air , if you have these 3 it will start , which one do you not have
Jan 12, 2014 | Poulan Pro Pr621 21-Inch 208cc LCT Gas...
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Oct 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
1,128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
