Question about GE WSXH208A Front Load Washer
Last few weeks there is a foul odor coming from the washer
Bad odor during the hot cycle
  • julia_lyles May 22, 2009
    the unit is 3 years old and this just started in the last 2 months. I usualy allow the dooor to remain open so that no moisture will stay in the drum, and clean the comparment where all the detergent and fabric softner is loaded, on a monthly basis. I have even run a bacterial level hot cycle through and the smelll returned.
  • 20 Answers
How old of a unit? The new high energy effeciency washers are known for their "odors" due to the fact they dont drain out all water and it can mildew inside. Some solutions...leave door ajar after wash cycles , water will evaporate, there is products you can add every so many loads, one product being "affresh" ,,,some other people will run strong bleach load every so many loads it will kill mildew. These washeres have been out for years in Europe and they have same problems, its just inherent with product
Posted on May 21, 2009
  • j2sonke May 22, 2009
    do you see any discoloration around boot at door? is this only on a warm cycle?
Electrical/Rubber odor after complete cycle
You have a drum roller that has a frozen bearing and needs to be replaced. The rubber smell is the wheel burning up.
Feb 12, 2014 | Bosch WFMC 3200 Front Load Washer
Foul water smell coming from washer after using machine.
Check the hoses to make sure there are no leaks or standing water behind. Try running a cycle or two of vinegar water and baking soda water to kill any mildew that might be in the tub.
New washers often give off an odor described as a burning match or electrical smell. This is normal and is caused by the "wearing in" of clutch shoes and the heating of new paint on the motor windings.
Older washer odors are usually caused by leaving the washer lid closed when not in use. This does not allow air to circulate and dry out the moisture remaining in tub area. The air and moisture mixture becomes stagnant and creates an odor. When washer is not in use, leaving the lid up/open for air circulation will help prevent odor.
To get rid of odors inside of washer follow the steps listed below:
  1. Fill the washer with hot water; set at regular speed & longest time.
  2. Add 3/4 cup of Calgon Clothes Detergent. (Baking soda can be substituted) .
  3. Allow washer to complete entire wash and rinse cycle.
  4. If odor lingers, repeat entire process.
Oct 18, 2009 | Washing Machines
Smelly clothes, nasty towels. Temporary solution.
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
I hope you find this Very Helpful and best regards!
Sep 20, 2009 | LG WM2688HWM TROMM SteamWasher
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
WATER IS COLLECTING AND STAYING IN THE GASGET AND HAS AN ODOR, HELP, Please
Betty, this is problematic of all front loading washers. I have some helpful suggestions, which have helped us with our own front loading washer.
First, whenever you're done doing a load of laundry, don't close the door all the way shut. Leave it open a couple of inches for a day to let it air dry out, which will prevent the nasty smelling odor you're getting.
I also take a small rag/washcloth to wipe out the door seal/gasket after we're done washing, that way, there's less water to contribute to foul odors, etc.
The other thing we discovered is to make our last load of wash the hot water wash, whenever we're doing whites, or the stain cycle. This helps get rid of any gunk that might hang around between wash days.
Now we don't always have a hot water wash everytime we do laundry, but by just wiping out the gasket and leaving the door open, we eliminated the odor issues completely.
Frankly, the gasket shouldn't have to be wiped out when you're done washing, but that's a design issue that we've overcome with a simple washcloth. So just do these simple steps and you'll save yourself some frustration.
We really like how clean our laundry gets with the front load washer and how little water is needed to do a load, so we've decided it's worth taking the time to wipe the gasket once we're done for the day, and to leave the door open to prevent any nasty odors.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Foul odor when I start a load of laundry
Obviously this problem exists on this manufactured machine (Cabrio). It has to do with the design of the machine and the HE detergent required to be used. We are on city water and the smell is sewage gas. Hence, do your whites last with lots of Clorox/bleach, cause the detergent isn't strong enoug to kill the bacteria growing in the pipes. That being said, P
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBK
Bad order during final rinse
the top load f/p washer is a "high efficiency" unit and has to be used with "HE" type soap. it is a non-sudsing soap and if you are using low or regular soap then the residues are not rinsing out causing the odors. they do make a special cleaning tablet called "affresh" it is designed to clean out any residues caused by your using too much or the wrong type of soap.
you can also run a cup of bleach on the longest cycle with hot water and see if thats helps too.
Dec 28, 2008 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag Neptune Front Load Washer. It spins the water out of my clothes good, but when the Washer stops and I take my clothes out, when I spin the inside by hand I can hear water between the drum...
water sound when spinning by hand totally normal, they use water as a counter balance, built into tub assy. as far as the mod/midew odors a few things things can help, first make sure youre using an HE detergent(HE detergent specially formulated for front loading machines) odors can be attributed to excessive amounts of detergent not completely broken down during the cycles, leaving the door ajar between cycles will also promote better air flow through the unit. and lastly using this product. new to the market made just for the front loading washers .
http://www.affresh.com/home.jsp
Mar 23, 2008 | Washing Machines
Odor when starting cycle
Check your water softener(If so equipped). This can cause foul odors in the water supply if not properly balanced or maintained. Good luck!
Sep 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
GE WSXH208A Front Load Washer Logo
203 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
