Question about Dunlop Standard Tortex .60mm/ 12pack
My bicycle pedal is stripped and I can't get one on. How do I fix this? Thanx
My bicycle pedal doesn't stay on my bike. My threads are stripped! Could somebody please explain to me what I should do to fix this problem.Its a Dunlop FS 767(21 speed)
    President:
  • 1,138 Answers
Depending on left or right you will first need a crank puller to remove the crank in order to replace it. You will be better off taking it to a bicycle repair shop. Cranks usually only come in sets but the shop may have a spare or they might be able to order you a seperate one. The same applies for pedals. If the threads in the crank are not too damaged you might just need a new set of pedals or one replacement. Hope this helps.
Posted on May 23, 2009
Volume pedal will not stay in up position
Worn teeth on belt or guide is slipping. Tighten or repalce as needed.
Aug 18, 2014 | Roland Boss Fv-500l Stereo Volume...
My Boss ME-70 Pedal doesn't fade out smoothly
Hi
Not an answer but a repeat of your question. Did you manage gto fix this as I believe my unit may suffer from the same problem. Thanks
Apr 17, 2013 | Boss ME-70 Guitar Multiple Effects Pedal
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I am using the stock pedal that I got with my set 6 years ago. I know it's time for an upgrade but really, I can't afford it. First off, the piece that connects the chain to the main bar (sorry for...
It is NOT clear how the parts are loose. If they are threaded things, go to the hardware store and get a product called "Threadlocker" or "Loctite" and use as directed. Clean the parts with alcohol solvent before applying the Threadlocker. If threads are too far gone, then use JB Weld which is a filled epoxy to fill in worn part.
May 15, 2011 | Ludwig L415FPR 400 Series Single Bass Drum...
Hi I have a Digitech RP 300 Modeling Guitar Processor that lights up and will play the metronome tik but will not output the guitar, the guitar input is dead or semes to be. can any one help. thanks...
The metronome is built in software, but it proves that your output is working fine. That's good.
Try changing your patch cable from guitar>pedal. if that doesn't fix it, grab a screwdriver.
Open the pedal and check the input port - is there any bent pieces or blockages preventing the cable from contacting what it needs to? Is the solder broken, cracked, or missing? Are both contact points firm and in place?
May 11, 2011 | Music
Stripped threads on inner boom adjustment
Not uncommon problem with boom stands. Some of these have plastic collars with threads... they are for the most part unrepairable. If you need the adjustable function of this, almost anything you do will look like a hack job. If aesthetics are not important, carry a roll of Gaffers Tape. It is black and doesn't leave residue and you can FREEZE the boom at whatever length is good. I know the problem... I have two bad ones myself. I will eventually make some metal collars as I have the necessary tools to do it. Also consider using those hose clamps as locks... not convenient but it will work.
May 09, 2011 | Atlas Sound PB21XEB Adjustable Boom Stand...
Happy with this product but, if i palm mute a chord, a boing sound follows behind... seems worse with the dist. dial turned past 11 o clock, whats going on? thanx- chris
When you palm mute you create a low frequency pulse which then "rings" in the DSP system of the distortion pedal. It is the nature of the beast. This pulse is to low to be heard directly and is kind of a "step response"... It is like plunking the springs in a reverb tank.
Jan 28, 2011 | Boss MD2 Mega Distortion Pedal
Sustain pedal on Yamaha DGX not working
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Dunlop Standard Tortex .60mm/ 12pack Logo
864 people viewed this question
Top Dunlop Music Experts
Michial Gueffroy
frankrome
rhodesworks
Are you a Dunlop Music Expert? Answer questions, earn points and help others
