Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
Convergence Problem Hello, my name is Josh and I have a Tosh Theatreview projection TV. The problem is with the convergence. Then I go to the secound convergence screen (push 1-9) the red will not come down in 3,7,and 8. On 7, it is pretty high and looks it is being shined from an angle.
  • 6,784 Answers
There is a convergence board located inside the set that regulates the alignment procedure. this board is malfunctioning and there is a chip set on the board that has failed. you will need to replace this board in order to restore proper convergence functions.
Posted on May 21, 2009
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
Convergence...again
Please read my solutions for Tosh "H" line convergence issues.
Check fuses F850,F851,etc.......use STK394-160E upgrade
IC's.....save $.....Use Hitachi kit # X 480293.............Also,
solder wire jumpers on signal board........................T.
Apr 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 46wh08b
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 42H81 42" Rear Projection...
Tosh widescreen ghosting vertical lines
there is no convergence adjust in a 32" tv. Convergence is done when there is more than 1 picture tube, ie; 50" projection sets have 3 tubes so convergence can go out. post the model number of your set and we can help more, BMW Rider
Dec 14, 2007 | Televison & Video
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
