Question about Goldstar Microwave Ovens
Touch screen not working - Goldstar Microwave Ovens
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
Khhs179lss touch pad replacement not working
If by "touchpad" you mean the touch screen (LCD assembly), those and their connecting strips are very fragile.
If the screen is not lighting after reinstallation, I would first check to be sure the white 3-wire cable is properly plugged back into the lower power board.
If it is, and everything is connected correctly, then you may have received a defective touch screen (LCD assembly) and would need to return it for replacement.
Again, these units are very delicate and the connectors are finicky.
I have an unedited video that shows you how to remove the LCD assembly. It would be useful in reassembly as well.
It is here:
http://www.microwavedisplay.com/lcd_assembly_removal.avi
Apr 25, 2013 | Microwave Ovens
What's your problemPvm2070sm1ss ? touch screen control panel intermittently stops working
The touch screen has built in semiconductors that sometimes become intermittent, the only solution is to replace the touch screen.
May 17, 2012 | GE Microwave Ovens
Pmor30b touch screen does not work
The touch screen is defective or the ribbon wire has become loose.
Mar 15, 2012 | Microwave Ovens
G2 touch screen doesn't work any longer
You must remove the vinyl cover from the control panel and wipe down the face underneath it with denatured alcohol. It's pretty tricky depending on your mechanical caliber.
Then clean the inner side of the vinyl cover the same way. Caution don't soak the power unit just dampen a cloth, this goes for the cover also!
Aug 13, 2009 | Microwave Ovens
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Whirlpool microwave g2- touch screen. The touch screen does not work properly. If you touch a command a differnt command/menu comes up. Some menus are inaccessable.
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 10, 2008 | Microwave Ovens
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Microwave Ovens Logo
419 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
