Question about Sharp MX-3501N All-In-One Printer
Registration jam - Sharp MX-3501N All-In-One Printer
How to solve E03 error problem?
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON. Jam at the registration area due to registration timeout
error
Oct 03, 2016 | Toshiba e-STUDIO166 Printer
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
My printer reads," Media Jam Registration" It of course will not print. I think I have cleaned all the jammed paper out of it but still will not work.
The paper registration senor accurator that tell the printer that paper has arrived and left the registration part of the paper flow may be broken (Sensor may be filled with paper dust) the accurator may be jammed.
Aug 09, 2010 | Minolta magicolor 3100 Laser Printer
CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
Apr 16, 2010 | Canon Office Equipment & Supplies
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
Jose ask: minolta di470 keep jamming after registration, thank
Might want to check the Drum section and or transfer and separation assy.
Dec 21, 2009 | Minolta Office Equipment & Supplies
From cold the fist page to print jams error on printer Media Jam Registration If you print a job then, run another whilst it is still warm it's fine. Just printing from cold it 90% of the time jams (Media...
Print jam problem -see here for solution, worked wonderfully!
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/186ca4b0866ef839c1256f910078f284/$FILE/MC3300-Paperjam%20registration.pdf
Jun 15, 2009 | Minolta magicolor 3300 Laser Printer
E3co e3eo toshiba 451c
E3C0 indicates LCF transport jam (not reaching the registration sensor).
Open the jam access cover. Is there paper in front of the registration sensor?
YES-> Remove the paper.
NO->Is the registration sensor working? (Perform the input check: 03-[FAX]ON/[9]/[E])
If NO ,
1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN338 on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open
circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open
circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
If YES:
Are the upper transport clutches (high/low speed) working?
(Perform the output check: 03-439, 440)
Feb 10, 2009 | Toshiba E-Studio 3511 Color Copier
Jams at registration roller!!
Jams at the registration roll often come from one of the pickup rollers breaking a pin that keeps them in place on the feed shaft. They are D shaped rollers about midway back when you remove the tray.
They will be stopped in different positions.
Online at Xerox.com there is a complete parts list under support and drivers.
Apr 19, 2008 | Xerox Phaser 6250DP Laser Printer
Tally 8024 Registration Jam
if you have the original disc the printer came with, uninstall and reinstall the driver's, that should clear it up.. if you don't have the disc, go to the website and download them from there.. let me know if this helps.. what type of printer is it? manufacturer? thanks, d
Feb 26, 2008 | Office Equipment & Supplies
Sharp MX-3501N All-In-One Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
