Question about Garden
Spark plug for Komodo edger - Garden
3 Suggested Answers
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
adrnlnrush19
  • 3 Answers
SOURCE: weedeater pe550 no spark at plug
Check the coil.
Posted on Sep 05, 2012
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
Test ignition coil honda gx25
Okay. You have eliminated the plug. Now disconnect the coil kill wire and try for spark again. Also check grounding between the coil laminates and the cylinder with you ohm meter should read zero.
If grounding okay and with the kill wire disconnected you still get no sparks then replace the coil pack as it probably a failed internal trigger which can not tested for.
Dec 31, 2014 | Atom ATDDLX 25cc 4-Stroke Honda...
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
Checking the spark
Remove the spark plug, install a spark tester into the plug cap ( these are a simple device normallt a dummy spark plug with a large gap ) earth the body of the spark tester well against the cylinder wall, make sure it is away from the open plug hole ,switch the ignition on, and crank the engine, you should see a spark at the tester, tester are readly available from dealers or on e bay.
May 31, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
Clean spark plug 2 cycle engine
Hi chldrz...
Remove the spark plug, clean post and arm with a wire brush, and then use light sandpaper to clean and level the two firing surfaces...(the post and the arm)
Replace plug if it wors fine, if not replace the plug.
Please take time to rate me
Thanks,
Bud
Feb 20, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
Spark plug wire install on ryobi ss26 edger
if the clip on the end broke off that can be replaced but if its on the coil end you need to replace the coil
Apr 07, 2012 | Garden
Can't start my Pe550 Gas Edger. I cleaned the air filter. I'm having trouble getting the old spark plug out to replace it. How do I do it, and what else could be the reason for it not starting?
Hello rne.... Take your edger to any auto parts store and either borrow or buy the correct spark plug wrench to remove it. Have them remove it for you to check it and see if you have any serious problem that a bad spark plug might show. Then purchase a new spark plug, have the store gap it and install it. They do this fo no fee.
Once you have a new spark plug, new, fresh fuel with oil added to the fuel mix, and your clean air filter your edger should start right up. If it doesn't get a can of starter fluid, give the air intake a couple of squirts and start it up. If it stalls again get a helper to spray more starter fluid at the air intake until you run it for at least a full minute on the starter fluid. That will clean out any crud that is causing your troubles. Joe
Jul 12, 2011 | Poulan Pe550 Gas Edger
Troy-bilt gas edger trencher won't start. Spark
Oct 25, 2009 | Garden
My weedeater edger over heats and freezes up. it gets very hot, smokes around the spark plug, the spark plug is coverd with soot and it won't start again
Are you using mixed gas? The gas needs to be mixed 50:1
You will have to use 2 cycle oil. If you are using mixed gas, than you can buy a cooler spark plug.
Sounds like the spark plug is not properly gapped.
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
