Vehicle Parts & Accessories Logo
A
Anonymous Posted on Sep 25, 2017
Astrostart tx50b My AstroStart TX50B system works great. It is my remote that is not working properly. Have installed two sets of new batteries and both lasted only a couple days. Would there be a short in the wiring? Can I purchase another remote? (Model TX50B, FFC 15F, TC 1854A, one single silver button with a small green laser light about the button. Can you help me?
Derrick Schultz
Level 3:
Top Expert:
  • Vehicle Part... Master 11,405 Answers
  • Posted on Jan 22, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2330310
Points
23972
You can try out some guide from reliable-store
they also provide live chat feature for instant help and it's very useful
using that I fixed my own excavator 5-6 times without any other help
plus free so whats harm in not getting
1 Related Answer
Anonymous
  • Posted on Apr 03, 2010
SOURCE: Bought a car with an old Astrostart remote
i have an astro start remote but i tried to hook up a trailer brake now the vehicle wont start
Will this battery work in my astrostart HST 5225 remote? I bought a RRS 5225 it plugged in but full charge it worked but didn't last a day. did I just get a dud?
REMOTE START, CRAZY ADD ON.
WHY NOT ASK THEM FOR SUPPORT.
MY GUESS IS WRONG BATTERY.
WHAT MEANS RRS? A HUGE TYPO FOR RSS???????? WOW IF TRUE.
https://www.astrostart.com/Products/RemoteStartSecurity/4306/RSS-5225.aspx
i READ THE MANUAL THERE RSS5225
IT SAYS CLEAR AS DAY THIS.
:Your remote is powered by an internal rechargeable battery that can only be serviced by an authorized Directed dealeR"
READ THIS? PAGES ON CHARGING IT
https://www.directeddealers.com/manuals/OG/AstroStart/RSS-5225_OG-Eng-2.pdf
PAGE 7 CHARGING WITH USB
THE FOB IS 13 YEARS OLD RIGHT.
AND NO BATTERY LASTS FOR 13YEARS, AND MUST BE REPLACED
SO PULL IT OUT AND POST PART NUMBERS ON IT.
I have the AstroStart RS415 programmed.
I have been searching 10 minutes and find nothing regarding it being compatible. Your best bet is to go to a local alarm installer and ask them to set it up. Or just try it.
https://www.google.com/search?q=AstroStart+rs415
AstroStart 2611D-TX 1-Way 1 Button DS4 Replacement Remote Control Transmitter
  • AstroStart Model 2611D-TX
  • 1-Way 1 Button Replacement Remote Control Transmitter
  • Orange LED
  • FCC ID: EZSDEI7616
  • Includes Key Ring
  • Compatible with **** DS4 / DS4+ Systems ****
  • Up to 1/2 Mile Range
  • Uses CR2016 Batteries (included, in remote)
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Astrostart remote start
Ck battery install they right way? Or bad remote!
1helpful
2answers
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
