Question about Philips Audio Players & Recorders
Bluetooth I am hooking up the iPad via eighth inch audio cable as the iPad adapter is the wrong size, I can't get the Bluetooth mic to hook up.
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
RickOz
  • 145 Answers
SOURCE: Trying to connect cable box....
You should be able to pick any open audio device unless it says pre-amp only. If your manual shows a connection for a CD player or similar device it should support the cable box.
Good luck and thanks for using FixYa
Posted on Mar 17, 2009
renx
  • 71 Answers
SOURCE: No audio from TV on Harmon Kardon AVR35 Receiver
I am attaching some pictures that will show a couple of wiring schemes based on the type of home theater you have. If you have questions with the set up of your HK receiver, please reply with those questions prior to rating your help.
Posted on May 05, 2009
mlapres
  • 757 Answers
SOURCE: i just bought a yamaha rx-v365 receiver and hooked
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Posted on Nov 25, 2009
tvservice306
  • 458 Answers
SOURCE: The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Posted on Mar 21, 2010
I stream live football games to my IPad. I have a Samsung 60 inch that uses the same source for Wifi as iPad. How can I display the game being streamed to the iPad on the T.V.?
Good day!
the simplest way to connect your iPhone or iPad to your TV is to use a cable like Apple's Digital AV Adapter, which connects your Apple device to your TV's HDMI port. You'll also need a standard HDMI cable- just buy the least expensive one you can. Then hook up the iPad to your TV, start your steam and enjoy!!
i know this answer is simplistic but sometimes this is the best way to go. Good luck !
Oct 07, 2017 | Miscellaneous
How do get my Acer lconia a3 10 inch iPad connect to the TV I've connected with HDMI leads but don't get anything
First off, determine if you have an Acer Iconia A3 tablet or an iPad.
If you have an Acer Iconia A3 tablet, then connect the HDMI port to a good quality HDMI version 1.3 or better cable. Make sure the ends match the sizes you need for your tablet and television.
If you have an iPad, call up the genius' in your local store to get them to walk you through how to hook it to your television.
Next, start playing something on whichever of your tablets, music, video, or some other type of media. Make sure to test before hooking it up that it is something that actually plays on the tablet you have, and has video and/or audio. If nothing plays on your television, then check the cable connections are properly seated.
Mar 02, 2015 | Acer Computers & Internet
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
Hook up eventide harmonizer to the pmp 6000
There are many models of the Eventide and how to hook them up will vary and depend if you have multiplle mics that are to be serviced. If you have multiple mics, I would be tempted to run the mics into some of the channels of the PMP but tur their faders to zero and send them to MONITOR 1. Come out of the MONITOR 1 jack to go into the Eventide and then run the Eventide into one of the line inout channels like 19/20. You would need to use balanced connections and some adapters from XLR to 1/4 inch to make the connections. There are MANY ways to configure this and depends what you are trying to do. If all audio is to go through the Eventide, then wire it as an "INSERT" for the power amp. This would require a special cables.
Jan 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How to hook up a sound system
Go to Radio Shack. Find the phono adapter and cable section of the store. The adapter you want has a one eighth inch male plug on one end, and a set of female phono plugs on the other. Insert the male end of the adapter into the stereo headphone jack on the side of your television. Run a set of phono cables from the adapter to your receiver. Turn the volume of your television up to the maximum (100.) You should be able to switch between the different surround settings in your menu.
Jan 06, 2009 | Polaroid FLM-4234BH 42 in. LCD HDTV
D510 how can I hook up to my stereo?
The two ports on the laptop are most likely a mic input and a headphone output.
Connect a cable (stereo) from the headphone output to the stereo input of your amp.
Jan 01, 2009 | Dell Latitude D510 Notebook
14 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
