Question about Garden
Engine serial - Garden
I want to know where is engine no.of isuzu 4hl1 engine model 2005
the serial, ?
in what country?
each country has import laws.
that dictate the type of serial and locations,
on some engines in some countries, there are none.
all facts.
Answering for SERIAL. use that word,
or engine ID and sequence number.
Nov 07, 2016 | Isuzu Cars & Trucks
I have a 2010 Chevy impala LS instrument cluster and it has a 20 pin plug I'm trying to figure out which wire's on the back of the cluster are for the speed sensor, rpm, gas, and temp wires.
Boy your way off base . All the gauges are inputs from the ECM - engine computer . The VSS - vehicle speed sensor , ETC - engine coolant temp sensor , sending unit in the fuel tank , All this sensors input the engine computer . The PCM then sends this info on the GMLAN serial data bus ,communications network . The Instrument cluster has a microprocessor inside that translates this info an controls the gauges. You probably have an instrument cluster problem or a communication network problem . Your best bet is to take your vehicle to the dealer or some other qualified repair shop. Need to have it checked for DTC'S - diagnostic trouble codes.
Indicators and Warning Messages
Refer to Indicator/Warning Message Description and Operation.
Engine Coolant Temperature Gage
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The IPC receives the coolant temperature information via serial data message from the body control module (BCM). The engine coolant temperature gage defaults to 60?°C (140?°F) or below if:
The ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications with the ECM.
The IPC detects a loss of serial data communications with the BCM.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the fuel level percent. The body control module (BCM) sends the fuel level information from the ECM to the IPC via a serial data message indicating the fuel level percent. The fuel gage defaults to empty if:
The ECM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates in the IPC.
Odometer
The vehicle odometer is calculated and stored electronically in the instrument panel cluster (IPC). The IPC contains a season odometer and trip odometer A or B. Momentarily press the trip/fuel button in order to toggle between the season odometer and the trip odometer. Press the set/reset button for greater than 0.25 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the engine control module (ECM). The IPC calculates the mileage based on the serial data vehicle speed information from the ECM. The odometer will display 'error' if an internal IPC memory failure is detected. The odometer displays either miles or kilometers and can be set through the customization menu in the driver information center (DIC).
PRNDL Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the gear position. The PRNDL display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the body control module (BCM).
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed as determined by the engine control module (ECM). The IPC calculates the mileage based on serial data vehicle speed information from the ECM. The IPC receives vehicle speed information from the body control module (BCM) via a serial data message. The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of serial data communications with the ECM or BCM.
Tachometer
The instrument panel cluster (IPC) displays the engine speed as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine speed. The IPC receives the engine speed information from the body control module (BCM) via a serial data message. The tachometer will default to 0 RPM if:
The ECM detects a malfunction in the engine speed sensor circuit.
How to Diagnose Controller Area Network CAN Suggest you read up on C.A.N.
May 14, 2016 | Cars & Trucks
While driving antitheft light comes on and all the gauges go flat,car keeps runnig,want to disable system,not sure what to look for
Before doing something drastic ,have it checked out for DTC'S - diagnostic trouble codes . It may not be the anti-theft system ,gauges going flat would be more like a communication problem between modules . PCM / BCM / instrument cluster etc.. That also could cause theft light coming on . If your not sure what to look for ,take it to a ASE certified professional . You may render your vehicle useless if you don't know what your doing .
Serial Data Power Mode Master
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle, the PMM is the body control module (BCM). The PMM receives 3 discrete ignition switch signals to differentiate which power mode will be sent over the Serial Data circuits. The 3-wire Ignition Switch table below illustrates the state of these inputs in correspondence to the ignition switch position:
Serial Data Messages The modules that depend exclusively on serial data messages for power modes. stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to RUN. In this state, the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state, the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Refer to Indicator/Warning Message Description and Operation .
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the powertrain control module (PCM) or the engine control module (ECM). The IPC receives a serial data message from the PCM/ECM indicating the engine coolant temperature. The engine coolant temperature gage defaults to 38?°C (100?°F) if:
The PCM/ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications from the BCM.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the powertrain control module (PCM) or the engine control module (ECM). The IPC receives a serial data message from the body control module (BCM) indicating the fuel level. The fuel gage defaults to E (empty) if:
The PCM/ECM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than 14 percent, the low fuel indicator illuminates.
Odometer
The instrument panel cluster (IPC) contains a season odometer and a trip odometer. Momentarily press the trip/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The odometer is calculated and stored electronically in the body control module (BCM). The BCM uses the vehicle speed information from the powertrain control module (PCM) to calculate the odometer. The odometer displays 'error' if an internal IPC memory failure is detected. The IPC stores a backup copy of the odometer value incase the IPC stops receiving a valid odometer value from the BCM.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on the information from the ECM/PCM. The IPC receives the vehicle speed information from the BCM via the serial data circuit. The speedometer defaults to 0 kmh (0 mph) when the following occurs:
The powertrain control module (PCM) or the engine control module (ECM) detects a malfunction in the vehicle speed sensor circuit.
The IPC detects a loss of serial data communication from the BCM.
Tachometer
The instrument panel cluster (IPC) displays the engine speed as determined by the powertrain control module (PCM) or the engine control module (ECM). The IPC receives a serial data message from the body control module (BCM) indicating the engine speed. The tachometer will default to 0 RPM if:
The PCM/ECM detects a malfunction in the engine speed sensor circuit.
Apr 07, 2016 | 2006 Pontiac G6
11.5 Briggs Straton Poulan riding mower, location of MFG serial number
Depending on which your needing. The body model and serial decal is usually located either on seat or on the body under seat.
If it is the engine it depend if OHV or a L-head engine. OHV serial (date code) is on the valve cover. L-head is located somewhere on the engine's flywheel shroud.
Mar 11, 2015 | Poulan Garden
Please can you tell me the year of a Kubota KX121-3SS excavator Serial number 30896 ?? Brian
here is a link for Kubota that may help you. It uses the engine serial # to tell you when the engine was built. It doesn't tell you when the engine was installed, though, but it should be very close to the same. http://www.kubotaengine.com/products/engines/engine-serial-number-identification>
Feb 21, 2015 | Kubota Garden
I need to know serial number of engine in TIMBERJACK SKIDDER 240A with machine serial number 240ASEAX 847182 7300
contact the manufacturer on line and quote the machine serial number and ask for an engine serial number that engine.
Jan 13, 2015 | Cars & Trucks
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
