Question about Datacard Group SP75 Color Card Printer
After ribbon change, can't print ID card background colors - only text is printed
Hello, we have a Datacard SP55 ID card printer and it has been working fine until we changed the ribbon (YMCKT-KT) recently. Now it can't print the background color for our ID cards. Even on the test card it doesn't print the background and just prints the text. Any suggestions?
  • 1 more comment
  • katafono_k May 21, 2009
    Thanks for the reply. No, it didn't print normal at all after the ribbon change. We printed a few ID cards and all we got were either black and white cards or cards that were colored pink and yellow. As far as I can tell there were no setting changes.
    Thanks for the suggestions, I'll try that out and let you know.
  • Frank Zhang
    Frank Zhang May 11, 2010
    does it print normal for a while after the ribbon changed?
    any manu setting changed?
  • 39 Answers
The problem could lie in 3 areas:
  1. Printer
  2. Printer driver
  3. Card issuance software
I would start by changing the ribbon with a fresh one. As you probably know, the ribbon spool contains a chip that tell the printer what type of ribbon it is.
Next, I would run the clean up utlity for the printer and get rid of the driver then reload the print driver.
Lastly, I would back up all the projects and databases, uninstall the ID issuance software then delete the BIN directory.
Hope this helps
Next
Posted on Aug 19, 2009
  • 191 Answers
This machine use the thermal pressure to press out ribbon and card,
so you need check
1) your new installed ribbon is original parts or fake one
2) check again your ribbon install at properate possition and move normally when printing, or reinstall it.
3) check if there is any gap which will lost the presure balnace betwwen printer head and pressure base.
just give you some idea, send any question please
hope you fix it.
Posted on May 21, 2009
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
It is shadowing yellow when I print
Most likely it's either a dirty printer, or a printer than needs a calibration performed.
Printing color cards is done with a series of passes using a ribbon that has a series of panels - yellow, magenta, cyan, black, and a clear overlay. The card is positioned; a panel is printed; the card is repositioned; another panel is printed; etc.
This color "ghosting" or "shadowing" happens when the card is not positioned properly at the start of one or more of the ribbon-panel print-cycles. This can occur when the card slips on dirty rollers, or there is a sensor or calibration issue.
Both procedures are documented in the user manual, and at the Datacard web-site. I'd perform the recommended cleaning first. If it's been a long time since cleaning, I'd do it more than once.
If that doesn't correct your issue, the next step would be to perform a calibration.
If it is still not performing properly after the above steps, you may need to have the device serviced, as a sensor could be failed or failing.
Mar 17, 2015 | Datacard SP55 Plus Two-Sided Printer
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here: https://www.datacard.com/id-card-printer-support-and-drivers/sp55-plus-card-printer
Dec 02, 2012 | Datacard SP55 Plus Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
THe datacard sp55 color card printer is printing monochrome(black and white). I have done lots of setting changes but still couldn't manage tro print the right color. And the duplex module is not on the...
The printer needs to be serviced, The Monochrome issue could be related to a problum with the RFID chip in the take up wheal of the ribbon, but the duplex offset can only be adjusted by an authorized service provider using a special password and diagnostic tool.
www.TulsaBiz.net offers a depot service.
Aug 26, 2010 | Datacard SP55 Plus Printer
I have a Datacard SP55 plus and recently I started to get two white lines on the id card that I am printing and it goes right through the persons name so it is very noticeable I am not sure how to fix...
You have a physically damaged print-head.
The print head is in the cover and us user replaceable by pressing the lever inside the cover.
Print heads are considered consumables and need to replaced at maintenance. You can contact Datacard at there web site and they can have someone come out and change for, as well as service the printer. Or you can buy one online about $550 and change your self.
Apr 23, 2010 | Datacard SP55 Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
Datacard
To convert you would have to change system board, and buy new print head, it would be cheaper to trade in for discount on new printer.
tulsabiz.net for more info
Jan 17, 2009 | Datacard SP35 Printer
Datacard Group SP75 Color Card Printer Logo
625 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
