Question about Exergen Temporal Thermometer
How change batteries? can't open back cover - Exergen Temporal Thermometer
Hoe to change galaxy tab batery
I do not believe it is all that easy to take the back cover off. Depending on which model of the tablet you have you need special tools. A plastic picnic knife might be helpful but then there are a couple of screws to open as well.
The different models have slightly different process. See these sites.
Samsung Galaxy Tab 10 1 Battery Replacement
Samsung Galaxy Tab Battery Replacement
Samsung Galaxy Tab 2 7 0 Battery Replacement
Sep 02, 2014 | Samsung Galaxy Tab Tablet PC
How do you change the batteries?
Remove the Battery cover on the back of the remote. Remove the dead batteries. Put them in recycling Open the new batteries and install them paying attention to polarity. Replace battery cover
May 06, 2011 | One For All URC-4330 Remote Control
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
Walkman NWZ-S615F How do you change the battery on this walkman? We've had it 3 years, but hardly used. Will work when plugged in to pc, but will not charge battery. I see on ebay I can purchase new...
Yes.
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
Jan 22, 2011 | Sony Walkman Video NWZS615F MP3 Player
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 10, 2010 | Sentry Fireproof Safe
I want to open the back cover, how do i change the nokia 6700 battery?
Push the back cover downward (towards the bottom), it'll open up..
You can refer to this tutorial.. Nokia 6700 simcard-battery installation
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | Nokia 6700 Classic Cell Phone
How to change batteries on ku916aa
1. There should be a cover on the bottom with a release lip the batteries are here to replace. this is located right below the on/off button.
May 29, 2010 | HP Wireless Optical Mouse
Sir, My mobile is Nokia 6500 model. In contact settings,at first it was set as contacts>>settings>>"memory in use"-PHONE AND SIM. By mistake I have changed the option of "memory in use" to...
usually the phone memory security code for nokia mobiles will be 12345, until it is changed manually. try this code... else, u have to consult the service provider i guess.
memory card not detecting....
First you open gallery on screen. If the memory card ok the first item will be the name of your Card. If it is not found that means the card not detecting. You may do this.:
Open Gallery, then press the back ( battery cover ) of the phone and hold for one second, now see the screen, you can see the card name on first line. But when you take your hand back form the battery cover the display revert to the same as before.
The point of pressing:- near to the lense ( Just right side of the lense) . You know why ?. The memory card is located inside of that place.
This means there is a switch (Battery cover open / close) located just left side of the memory card, and there is a TIP projected in the same place at the Battery cover. When we close the back cover the switch become ON. Here is the problem.....!. The switch will not contact even you close the cover. When you press the cover hardly the switch become contact. when you remove the hand again it become open.
More clarification:-
In a new phone if you open the battery cover the memory card will not work at all. It will detect only after closing the cover.
this may help you.
Jan 08, 2010 | Nokia 6500 Slide Cellular Phone
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
Nov 25, 2009 | Kenneth Cole KC2315 watch
Changing the battery on Ericsson W810i.
u want to open back cover in order to do so u have to pull the back down its high force
Nov 20, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Exergen Temporal Thermometer Logo
56 people viewed this question
Top Exergen Home Experts
Donni Steen
Tom Chichester
Are you an Exergen Home Expert? Answer questions, earn points and help others
