Question about Cerwin Vega Audio Players & Recorders
Need a manual for a cerwin vega ht-12d sub
Satellite
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
jsinex2421
  • 62 Answers
SOURCE: cerwin vega ht-10d subwoofer won't work in yamaha reciever
Actually, I had the same problem with my JBL PB10. It was the cable. I had to buy a one direction shielded rca cable. If you put it in backwards it will not work. The cable was around 75.00. But it was well worth it. The first cable I tried was a cheap sony brand sub rca cable. I ended up buying the AR(Acoustic Research) 15ft. directional subwoofer RCA cable from Best Buy. Make sure you have your receiver set to the proper setting too. If you have it hooked to main, set it to main. If you have it hooked to the L.F.E.(RCA cable) set it on L.F.E.. Some have the option to set to both. If it is a non powered sub a RCA cable will not work. You will have to run your main speaker cables to the sub first, then from the sub to the speakers. It then "piggybacks" the Low Frequency signals from the receiver.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
SOURCE: I need fuses for my cerwin vega re 38 speakers
Should be 2.5 amp SLOW BLOW fuses. Not at home, but mine have a label near the fuse holder showing 2.5. Important to get the slow blow. I get mine at Radio Shack in a multipack (amp underwpowered, blow them often)
Posted on Nov 24, 2009
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
How can I hook up my cerwin Vega ht 10d subwoofer to my computer surround system
You'll need some adapter cables. I would probably try a Y cable in each front speaker line, then connect the pair from the left channel to the "L" binding posts on the back of the Sub. Same for the right.
Not sure of the configuration of your existing surround system. Essentially, you want to "Y" the left and right channels wherever you can get a hold of them and connect each to the back of the sub.
Apr 23, 2017 | Cerwin Vega Audio Players & Recorders
When turning on the power on my cerwin vega 15" sub the protect light which is a built in protection on the amplifier keeps coming on the power on light does not come on at all just the protect light
The sub could be shorted or the wire connections of the sub could be shorted, or there could be an internal problem with the amplifier such as a shorted output stage or failure of some other component(s)
Feb 21, 2013 | Cerwin Vega Audio Players & Recorders
grady66,
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
Specifications of cerwin vega pro stax scoop sub
http://www.cerwinvega.com/pro-audio/portable-sound-system/int-118.html
You can always contact Cerwin-Vega and tell them the model number to get the exact info you need even on older models.
-Chris
May 25, 2010 | Cerwin Vega Pro Stax 12" 2 Way Stage...
No sound coming out of speakers on my cerwin vega
spurdoggg,
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
136 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Vito Vacirca Jr.
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
