Question about Dell Inspiron 2200 Notebook
No E drive! Help!
My E drive has disappeared so its not picking up cds or dvd's in my laptop. When I go into device manager its there, with a yellow circle and exclamation mark in the middle, any idea how to fix this?
  • nirvaniac May 21, 2009
    Yes when i put a cd rom in the drive,it spins, and then stops, and nothing come up on the screen for it, and when I go into my computer to look for the E drive or CD rom drive, its not there...
  • Frank Zhang
    Frank Zhang May 11, 2010
    is DVD drive spin when turn on and boot in windows?
    could you check out DVD drive detected by bios?
  • 191 Answers
You may do something check
1) enter bios setup check CD drive is detected or not.
if not detected, you may take out the drive clean the plug and socket then set it back properattely. still not detect in bios so you need change other drive or put your drive to other laptop to make sure whether the drive is ok.
if the bios detected CD drive, that is your OS system does not recognize the drive, you need check your syastem environment maybe some changed, so recovery previous system environment, or reinstall OS.
2) all deal nothing fixed(CD drive good) that is your CD drive interface hardwre problem on the motherbord IO controler logic.
you need find a technician fix it.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 21, 2009
  • 1 more comment
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
  • Frank Zhang
    Frank Zhang May 30, 2009
I am unable to hear sound after getting windows reinstalled. Can anyone help me?
you need to install sound driver
go to device manager
at device manager there are yellow mark (?) or (!)
insert your motherboard cd driver
and install sound driver
the other way is at device manager right click at yellow mark and chose update drive, then follow instruction until finish and the yellow mark at device manager disappear
try to play sound
i hope this helpful
thank you for using fixya
Feb 23, 2011 | ASUS P5RD2-VM Motherboard
Tip
CD-DVD drive is not detecting/working
Click Start button, type Device Manager in the Start search box and hit enter key.
Device Manager window opens.
Expand Cd-Dvd Rom devices.
You will find Cd-Dvd driver listed here with yellow ! mark.
Right click on the driver and select uninstall.
It will get disappeared now.
Now minimize the Device Manager.
Click Start, type regedit in the start search box and hit enter key.
Registry editor opens.
Please locate then expand following subkeys :
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Now please select the following entry through cursor.
{4D36E965-E325-11CE-BFC1-08002BE10318}
Now look for UpperFilter or LowerFilter or both in the right pane.
Right click on UpperFilter and/or LowerFilter and delete them.
Press F5 key once and close the registry editor.
Maximize the Device manager now.
Click Action menu at top of Device Manager then click Scan for hardware changes.
It will reload the Cd-Dvd driver without yellow ! mark and the issue is resolved.
on Sep 16, 2011 | Computers & Internet
Dvd rom reads only dvd not cds
hi frnd...
try finding out the name of Ur DVD rom.. it will be available in the DEVICE MANAGER.. to access device manager just type DEVMGMT.MSC in RUN option... once u have located the name of the DVD drive .. just go to the DVD drive vendors site and download the firmware of the dvd drive and instal it and restart ur system it will work fine.. while installing the firmware the LED on the drive blinks...
Oct 01, 2009 | Computers & Internet
My dvd driver is playing hide & seek with me.one minute it there,then it just disappear.what can i do to get it back
Does it also disappears in your Device manager? If it also disappears in device manager this could be a driver issue or loose dvd drive. Try to update the driver for the DVD player or try to unseat and reseat the DVD player on the laptop.
May 20, 2009 | HP Compaq Presario V2000 Notebook
System does not recognize CD/DVD Drive
The yellow triangle means there is no driver installed. There is 3 ways to get a driver. In most cases you right click on the hardware in Device Manager and download driver or reboot and Plug n Play should pick up driver automatically. If none of those work then the only option is to load it thru the add/removal in the control panel using the disc that accompanies the softeare.
Apr 01, 2009 | Dell Studio 15 Laptop
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
My dvd rom drive won't read any disks
The yellow exclamation point in the device manager means there is a problem with the drive. It could something as simple as installing a driver for the drive or it could be that the drive is bad. Hope this helps & please rate my answer. Thanks.
Dec 28, 2008 | Pioneer DVR-107D DVD±RW Burner
E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Dec 18, 2008 | Computers & Internet
About my dvd writer
The issue can be either with the Hardware or the software.
Make sure that this issue happens wiht all the CDs or DVDs you are using or able to used eariler.
First, check if the DVD Drive is listed in My Computer or not.
If yes, try uninstalling the DVD Drive from the Device manager by following the steps :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to DVD/CD Rom Drives to expand the tree.
Right click on the DVD Drive entry and select Uninstall.
Confirm if you get any message and close the Device Manager and restart the Notebook so that the DVD Drive Drivers will be reinstalled automatically.
Uninstalling DVD Drive Drivers in Vista :
Click on the Start Menu and type in Device Manager in the search field.
Click on the Device Manager from the results which will open the Device manager window.
Follow the same instructions to uinstall it.
If you find the yellow ! marks in the Device Manager, you may have to do some modifications in the Registry by following the instructions in the links below :
For XP :
http://support.microsoft.com/kb/314060
For Vista :
http://support.microsoft.com/kb/929461/en-us
you may have either the Upper or Lower filter or both.
Delete both of them and restart the Notebook.
Finally, try removing and reseating the DVD Drive from the instructions available in the Manual in page number 135 of 310 :
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
If the issue repeats, issue can be with Hardware.
Jun 25, 2008 | HP Pavilion dv2000t Notebook
Toshiba Satellite A75-S206 DVD\CD-RW drive problem
Hello GeneMat,
I am Romeet,i will try and help you with this problem.Seems it could be an issue with the Combo DVD Drive's Driver Software or Firmware.
Try This:
From your Desktop:
Right Click " My Computer" Icon and select "Properties"
Go to "Hardware" Tab and select "Device Manager"
Under Device Manager, scroll down to the "DVD/CDROM Drives" menu and click on the plus ( + ) Sign next to it
Right Click the Drive name eg " Toshiba DVD-R TSST 2313" and select " Uninstall" Click yes to any prompts and restart your Laptop.
After rebooting, Windows XP should pick up the drivers again, so wait a while for it to complete and until it notifies you that " Windows successfully completed installing your new hardware" or something to that effect and then try using the software cds again
Best of luck!
Regds
Romeet
Dec 01, 2007 | Toshiba Satellite A75-S206 Notebook
Dell Inspiron 2200 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
