Question about Whirlpool GHW9150 Duet Washer
I'm trying to remove the screws on the bottom panel for a F02 drain problem. What size of bit should I buy for that screw? Thanks!
I'm trying to remove the bottom panel for a F02 problem with the drain. None of my bits will work on the hexagonal screws they used. Anyone know what size of bit I should pick up? Thanks!
  • 10,865 Answers
Yes. you should go to a home depot or similar store and get a set of hex nut drivers.
Posted on May 21, 2009
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F02 code on duet washer mean?
Jul 28, 2014 | Whirlpool duet Washing Machines
Duet F-02 code
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
More...
A friends HE3 would not drain. F02 error message was showing. The filter had coins, pencils, a wire from a bra, and a piece of cloth that was stuck in the pump impeller vanes. Cleaned it all out put it back together and it worked.
For others that encounter the same problem: (The fix is very easy).
Unplug the washer. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap. Remove the drain filter cover cap by turning the filter cover cap counterclockwise. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand). Clean the cover cap gasket and the gaskets mating surface. Replace the filter and close the cover cap firmly. Run a short wash cycle and check for any leaks at the filter cover cap. Replace the kick panel if none are found. Good luck.
Sep 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer, F02 error is flashing on board. What does error code mean?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Mar 11, 2011 | Kenmore Washing Machines
My washer keeps saying SUD. what is wrong?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 31, 2011 | Washing Machines
I have a kenmore elite oasis 110.27042602 with fault code f2. Should I try replacing the control board? I already cleaned the contacts on it. Thanks!
Hi
Daniel
Jan 25, 2011 | Kenmore Washing Machines
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
F2 code
Hi
Daniel
Jan 01, 2011 | Washing Machines
Washing Machines Logo
371 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
