Question about LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator
LG LMX21981ST water flow is slow - LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator
4 Suggested Answers
burdfrenzy
  • 348 Answers
SOURCE: Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Posted on Jul 11, 2010
  • 12 Answers
SOURCE: lg 27.7 w ice maker
If your ice maker kit has a piercing nozzle you would want to change that cause they build up water deposits very quickly
Posted on Dec 15, 2010
richroth
  • 9472 Answers
SOURCE: water flow too slow on lg fridge
The solenoid on the water inlet vale is faulty and need to be replaced. Here is the part to order.
Posted on Nov 24, 2012
Ice in bottom of freezer drawer. Drain pan is dry. Haven't been able to locate the drain hole.
You'll have to probe around and find it. It's likely that something is plugging up the line, possibly a slime mold that acts like gelatin where it plugs up the tube. You might be able to unplug the line using hot water in an ear syringe. Insert the syringe tightly before squeezing the bulb. You can use other methods or tools of getting the drain line cleared.
This might be helpful:
http://homeguides.sfgate.com/unplug-drain-refrigerator-21433.html
Donald
Jan 27, 2016 | LG LMX21981ST Stainless Steel Bottom...
Water flow too slow on lg fridge
Nov 24, 2012 | LG LFX25960ST Stainless Steel French Door...
Low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
Nov 17, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
Lg 27.7 w ice maker water dispenser has little 'water pressure slow flow on water dispensing
Dec 15, 2010 | LG Refrigerators
I have an LG side by side LSC27910ST The water
My fridge was hooked up with a self tapping fridge line. I had two different plumbers/repairmen tell me that if the water flow ever slowed I should switch it to a dual line water shutoff, with one going to the sink and one going to the fridge. I did this and it more than solved my problem. The water now flows way quicker than ever.
Oh and I always had good water flow within the guidelines, as in filling a bucket with the line that goes into the fridge. It was a pretty easy fix that only involved one run to home depot. Make sure to note the size of the line that goes into your sink or even just take that hose with you.
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
Slow flow of water in washer
CHECK WHERE THE WATER LINES HOOK UP TO THE WASHER NORMALLY THERE IS A SCREEN INSIDE THE WATER INLET PORTS
Apr 28, 2009 | LG WM2233H Front Load Stacked Washer /...
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
May 23, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
