Question about Bachmann Spectrum Gp30 Diesel Locomotive Cp
Spectrum GP30 won't run, light works - Bachmann Spectrum Gp30 Diesel Locomotive Cp
Head lights Dont work on my 1989 geo spectrum what could be wrong
spectrum?
Fuses. check fuses first.
both head lights dead.? hi and low and flash.
and engine runs perfect.? as does all other electrics.????????
Aug 01, 2014 | 1989 Geo Spectrum
Have 1989 geo spectrum,fan not running,but disconnected run hot it works,pulled relay condensor fan relay gm94109148 what other parts I can ck to cause fan not to work.
I am having the same issue with my '89 Spectrum. However, I lost the heater fan, gauges, and dummy lights at the same time. All fuses are good. (?) Did you have any success replacing the thermostat?
Oct 08, 2012 | Geo Spectrum Cars & Trucks
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
JUST WANT TO KNOW THE COLORS OF THE RAINBOW AND WHAT ORDER?
Although I am not sure what this has to do with dryers, the color spectrum of a rainbow runs from purple to yellow. The visible spectrum runs from black to white with ultraviolet and infrared beyond the visible spectrum. Purple, violet, blue, red, orange, and yellow are the colors in a rainbow.
Sep 10, 2011 | Dryers
Got a ZX Spectrum +2 with built in datacorder from eBay. The actual computer appears to work, but the datacorder won't work. It makes a noise when I press buttons such as play or fast forward but...
I know this is an old Question but the answer related to it is simple.. Check the 2 drive bands underneath the tapedeck loose bands will need changing this was always a common fault on the spectrum + 2
Sep 03, 2011 | Computers & Internet
My miller spectrum 701 was set up for 1ph 230 and got plugged into 460 and fire shot out of it several times.what would it take to fix it?
I'm not recommending that you do this, but if you were to open the covers you'd be able to identify visually the blown boards and on the boards are the codes for re-ordering. This is not a guarantee that other boards won't be fault, but they should be ok.
Jun 13, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
1987 chevy spectrum just got it for son. sat for a year (w/fuel in it). cleaned carb, added treatment, changed fuel filter, plugs. runs good accept when you are at a stand still (stop light, sign, etc.)...
If it's a carbureted system, maybe the idle speed can be adjusted with a screw. Not sure on the Chevy Spectrum.
Is this Chevy Spectrum the carbureted model or the Fuel Injected model?
If carbureted maybe the idle stop solenoid is bad.
This will be located near or on the carburetor throttle cable pulley.
Nov 12, 2010 | 1987 Chevrolet Spectrum
Bachmann Spectrum  Gp30 Diesel Locomotive  Cp Logo
26 people viewed this question
Top Bachmann Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
