Question about LG LMV1680ST Microwave Oven
LG fan comes on unexpectedly
The fan randomly comes on when the microwave is not in use and the touch pad doesn't work for the fan. The fan will come on and not be able to be turned off by the touch pad. The fan is not controllable. It goes on all by itself even when the microwave isn't in use.
MicrowaveSvc
  • 9098 Answers
SOURCE: LG Microwave Oven LMV2053SW
That's common - it's a problem on your control panel. We regularly repair these control panels for only $32.50 nationwide. For critical safety info & detailed disassembly info, see our link in our FixYa listing here: http://tinyurl.com/yzjozk Let me know if you need further help. I appreciate your kind rating!
Posted on Jan 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 15, 2007
ginko
  • 19396 Answers
SOURCE: LG microwave not heating
If there is no power at all check thermal cutoff and control board.
Posted on Apr 27, 2009
  • 4 Answers
SOURCE: LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Posted on Sep 21, 2009
  • 4 Answers
SOURCE: Touch pad doesn't work LMVM1945SB Microwave
that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
My LG intellowave microwave's touch pad/control lights is coming on and I can set the time to microwave but the on and off touchpad doesn't want to work
The touch pad switch is faulty. You have to replace it
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | LG Microwave Ovens
Start enter button not working
If you know how to repair microwaves, see these youtube tutorials:
Fixed microwave number pad
Quick repair GE microwave touch control key panel doesn
Samsung Microwave SE 5E Error Fix
Lg Microwave keypad repair
No light? You can look for more videos or take it to a repair shop
Jul 13, 2015 | Microwave Ovens
Our lg stainless steel overthe range microwave oven will not start. When pressing start only says power 100
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
Mar 14, 2015 | LG Over-the-Range Microwave
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
Aug 13, 2013 | LG LMV1630 Convection/Microwave Oven
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Sep 20, 2009 | LG LMVM1935 Convection/Microwave Oven
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
I have an LG LMVH1750ST microwave convection oven. When I activate the fan for cooking purposes and then try to turn off, it does not respond. I have to pull electrical plug and reprogram for one minute....
From the owner's manual under OPERATION "VENT FAN":
"If the temperature from the range or cooktop below the oven gets too hot, the vent fan in the vent hood will automatically turn on at the 4-Speed setting to protect the oven. When this occurs, the VENT ON/OFF pad will not turn the fan off."
You should check your "vent fan auto time set" setting.
Here's one thing to try to set it to turn off after 10 minutes:
Touch the Vent ON/OFF pad, then touch the "5-SPEED VENT" pad until "level 4" appears in the display, then touch "AUTO TIME SET" the desired number of times.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | LG Microwave Ovens
LG LMV1680ST Microwave Oven Logo
53 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
