Question about John Deere Garden
LA130 lawn tractor
My machine shut down when I engage the blade clutch even with the lower blade attachment removed from the machine?
  • 666 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
  • 33 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
The mower blades are engaged at all times. The switch that disengages blades does not work. A safety issue exists. What can you advise?
Sounds like the switch is defective and must be replaced..in the meantime...locate the wire connecting to the electric clutch fro the bad switch, shut the mower off and disconnect the wire from the clutch..you can operate the mower when not using the blades....just remember make sure you shut it down before attempting to pull the wire off the clutch..this is only a Temporary fix...good luck..
Jul 28, 2015 | Husqvarna YT48XLS 48 inch 24 HP Kawasaki...
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor quits when engaging the blades
unhook your clutch and see what happens could be bad clutch
Jun 01, 2013 | Mtd Garden
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden tractor engine shuts off
Sounds like the operator present seat switch is not working. You can run the motor out of the seat, but not with the blades engaged. You didn't list what model, but usually hte seat switch is connected to the negative side of the battery, and grounds out the magneto, so you can't test it to ground. Put your tester on 12+ battery, and then to both sides of the seat switch. There is usually 4 terminals on seat switch. Some moodels have grey wires for the mageneto circuit, you can tell by whatever color also goes to the clutch switch too.
Aug 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 15.5 HP Sears Craftsman 42" riding lawn mower that shuts down when I release the clutch OR engage the blade. Starts and runs fine, but engaging blade OR releasing the clutch to go shuts her down....
Mar 09, 2010 | Craftsman Garden
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
12 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
