Question about Dryers
Whirlpool dryer not heating
Dryer is not heating and I replaced the heating element today. What else could it be?
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 221 Answers
SOURCE: No heat on Whirlpool leq8000jq1. Is it just the heating element?
There are several things that could cause this problem, here are a few common things it could be, before doing any checks you should always make sure you disconnect your appliance from it's power source.
  1. bad heating element, you can check the heating element for continuity with an ohm meter.
  2. bad thermal fuse
  3. faulty power cord
  4. bad thermostat
  5. tripped breaker or blown fuse from house power supply, check to see if you have 240 volt supply to your appliance.
Posted on Mar 15, 2009
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
Whirlpool Dryer LGB6000KQ1 - Dryer Doesn't heat nor does timer advance.
Probably the heating element. They go bad more often than timers.
Jul 25, 2017 | Whirlpool Dryers
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Jul 17, 2009 | Whirlpool LER4634J Electric Dryer
My dryer was working fine last night, then today, no heat. The vent is cleaned, nothing in there...heating element?
Heating element maybe not likely.
Probably thermal switch overheat protection tripped.
Try putting in lower heat mode (touch up or permanent press) see if you get heat.
Some thermal switches can be reset most have to be replaced. $20.00 to $45.00 Plus labor $??.?? to $???.??
Hope this helped. need more help MSG Back. Please rate. Good Luck!
Mar 12, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer not heating up
What you do is remove the rear dust cover. It could be the element located to the right, or it could very well be the Hi Limit mounted atop the heating element chamber. fd54e5e.jpg
Jan 18, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer not heating
I had the same problem today. After stumbling through the schematics (they were taped up behind the main control panel on top of the dryer) and ohming out a bunch of different parts with my multimeter, I finally took the heater element out and found that it had burned in two in a spot (I could see it once I took the element off of the dryer). I replaced it for about $80. The guy at the parts store said that is usually caused by a clogged vent, which is probably the case for mine, since my vent is poorly designed. I hope this helps someone.
Nov 07, 2008 | Whirlpool LEB6300 Electric Dryer
Open Questions:
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
