Question about LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator
LG LMX21981ST water dispenser getting stuck - LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator
3 Suggested Answers
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Posted on Sep 15, 2007
SOURCE: water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Posted on Mar 14, 2010
Ice in bottom of freezer drawer. Drain pan is dry. Haven't been able to locate the drain hole.
You'll have to probe around and find it. It's likely that something is plugging up the line, possibly a slime mold that acts like gelatin where it plugs up the tube. You might be able to unplug the line using hot water in an ear syringe. Insert the syringe tightly before squeezing the bulb. You can use other methods or tools of getting the drain line cleared.
This might be helpful:
http://homeguides.sfgate.com/unplug-drain-refrigerator-21433.html
Donald
Jan 27, 2016 | LG LMX21981ST Stainless Steel Bottom...
Water dispenser stuck on lmx25981 lg fridge
open the front of dispenser check spring might be broker or came apart.
Jun 26, 2014 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Water/ice dispenser sticking on
Sep 11, 2009 | LG LRSC-26922 Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Jul 23, 2008 | LG WM-2277HW Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Sep 11, 2007 | LG LRSC-26922 Side by Side Refrigerator
LG LMX21981ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
42 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
