Question about LG Televison & Video
Changing region code to all on a LG DH4130S? - LG Televison & Video
2 Suggested Answers
SOURCE: Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Posted on Jan 14, 2011
How to remove region code which prevents dvds from playing
Ive done this on an LG ages ago. Look on the net for your make and model. You should find it and the info for changing region codes.
Apr 09, 2015 | Televison & Video
I made my LG RCT689H region free (F8) which made my remote control go half crazy, but didn't memorize the original two-digit combination for reg 2. Does anyone know the code so I can hopefully get
I see you made the same error as me changing the default OP values. Can you in any way share these OP codes so i can change mine back to the original values?
thanks
Sep 01, 2012 | LG Televison & Video
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
Aug 12, 2012 | LG Televison & Video
I own a 5-DVD Changer with a Home Theatre System. It is an LG Model # LH-E932TB. It was working great then all of a sudden it now says ''CHECK REGIONAL CODES''. Does anyone know what to do...
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
Jul 09, 2011 | LG Audio Players & Recorders
LG DVS450H I need to make region free,its dvd player Any one know what code to make it region free? pls help
Greetings - There doesn't seem to be any simple (such as using a remote control to enter codes to change regions) but there is an alleged working software hack HERE.
Since this involves changing the software code on the player neither I nor Fix Ya hold any responsibility for any damage caused to your player if you proceed.
Good Luck if you try it out.
Regards and Thanks for using Fix Ya.
Mikeywaf
Apr 15, 2011 | Televison & Video
Aug 03, 2010 | LG Televison & Video
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Will
Mar 31, 2009 | Televison & Video
Want to know how to set my LG dvd/hdd player to multi region
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Jan 03, 2009 | Televison & Video
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
LG DVD PLAYER DV8621P
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9
Instructions for changing region code appear on screen,
Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
Jun 26, 2008 | LG Televison & Video
Televison & Video Logo
37 people viewed this question
Computer Repairing
Computer Repairing
