Question about Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit
Will only charge to 40 psi, is supposed to charge to 150
I have a porter cable air commpressor that will not charge past 40 psi. It is a 2.5 horse / 6 gallon. It is supposed to charge to 150. Please help.
  • Skinnerd1
    Skinnerd1 May 11, 2010
    At 40 psi does it stop running or continue to run but never build pressure?
    Is it an oilless type?
  • 323 Answers
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
Posted on May 22, 2009
Porter Cable 150 psi 6 gal compressor tank builds up to 150 psi but 'regulated air' stays at zero and, of course, no air out. Thanks
The attached link provides a work around,
There are repair kits available. Dissemble and make sure that you document the assembly for reassembly. Common problem.
Hope this helps.
Fixing Porter Cable C2002 Regulator
Aug 13, 2016 | Porter Cable Air Tools & Compressors
My check valve hose gets very hot, I saw a question, what is meant by regulated pressure?
  1. The regulated pressure is at the output of the pressure regulator i/e the air pressure being delivered to the air tool or spray gun.
  2. This can be set from just a few PSI up to about 180 PSI (on my Porter Cable unit).
Nov 12, 2013 | Porter Cable C2002 150 Psi 6 Gal...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
Air has started leaking around the plus/minus knob on the front of my "Porter Cable C2002 150 Psi 6 Gal Compressor." As a result it no longer can fill up with air. What can I do to fix it. Jim
They will let air out if you have turned the valve out too far, try turning it clockwise until it stops then open it by turning the other direction two or three full turns.
Don F
Aug 14, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Pressure does not go past 20-25 PSI
Hi
Perhaps it may be something to do with the setting of the pressure valve
Cheers
John
Jun 26, 2011 | Porter Cable C2002 150 Psi 6 Gal...
No air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Nov 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit Logo
295 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
