Question about RCA RV-9970A Surround Sound Receiver for Parts/Repair
Need to replace the volume knob
The volume knob cracked and broke off, the volume still works, I just need to replace the knob.
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
The volume knob from my right computer part Rev A00 broke off. Computer model Dell dimension 2400. Can I get a replacement knob and where?
Sounds like you broke the volume control knob for your speakers (Likely A215s)
Best bet, new pair of speakers as they don't sell replacement parts for the speakers themselves
Apr 24, 2010 | Dell Dimension 2400 PC Desktop
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Feb 09, 2010 | Behringer Eurolive B212A Speaker
A Fender 15G starter amp. The Volume is on full, however turning the knob down wont turn down the volume. I took off the knob but it appears to look ok. What else could I do to fix this problem?
The controll is broke and needs to be replaced. Most likley the amp had fallen over. If you cannot do this you can contack Pro Line Music 215-736-8055
Dec 11, 2009 | Audio Players & Recorders
I broke the master volume switch off. How I do I
I have a soloution that will work as long as you still have the metal shaft on it?
if it does go to your local electrical store and buy a new knob.
then all you have to do is screwthe knob back on to the amp.
please reply and tell me if that helps.
Aug 01, 2009 | Line 6 Spider Iii 30
My reciever volume cuts in and out and crackles when adjusting
You can CLEAN / LUBRICATEthe volume control know with a CONTACT/CONTROL cleaner, I use a product from Radio Shack, this works wonders on drum type electo mechanical devices which are basically volume control knobs, easy to do, just remove the round knob and spray into the openings with the small tube attached, and rotate in both directions, be sure to unplug the unit first, on a few occasions it is best to remove the front panel to acheive better coverage to the rheostat type volume body, anyway it always cures the crackling and distorting sound, I would give this a try before replacing the part.
Feb 14, 2009 | Technics Audio Players & Recorders
Volume control broken
You can purchase clear 2-part epoxy products at most home improvement stores. You will also need masking tape (or similar) a popsicle stick (or similar) a small piece of cardboard and a toothpick.
Mix the epoxy with the popsicle stick and apply a small amount to the exposed surface of the volume control's stem. Holding the knob in place, run a strip of tape from the top of the unit, across the knob and to the bottom.
These epoxies are very strong and fast setting. It's probably best to leave the tape for at least 8 hours but you should refer to the instructions for the epoxy you buy.
Good Luck,
BB
Jan 05, 2009 | Yamaha HTR-5830 Receiver
RCA RV-9970A Surround Sound Receiver for Parts/Repair Logo
20 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
