Question about Proform 560hr Treadmill Walking Belt
Power outage caused my treadmill belt to stop working
    Problem Solver:
  • 6 Answers
9 times out of 10, this will be a damaged 'lower control board' - Ben Bass Service Technician Since 2001 Phone 0403 969 946 / 1300 496 967 #GYMWORKS #HealthEquip #TreadmillBelts.com.au
Posted on Nov 24, 2014
I have a problem. Every time I try to run my treadmill the motor runs for roughly 2 seconds and then turns off. The power is still on, however, but the treadmill only runs in short bursts. How can I f
If it stops but you can still hear the motor running then I would check the belt tension. The force of you running could be causing the belt to stop but no the drive.
Dec 24, 2014 | Nordic Track Nordictrack C2100 Treadmill...
My treadmill stops wen runing and brings up er 27 on screen
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
Treadmill runs 5 minutes stops
There could be other possibilities causing the treadmill to stop but one of the most common issues is excessive wear on the belt/deck.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt
Dec 01, 2013 | Precor Exercise & Fitness
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
Treadmill stop working
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics
Try to run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP.
sincerely. God bless you
ernesto cuadra
managua, nicaragua
Mar 11, 2012 | Exercise & Fitness
Golds gym crosswalk 650 not working
Dear Sir:
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
See the block diagram that i did design for easy troubleshooting and diagnose.
2_15_2012_4_24_13_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 15, 2012 | Exercise & Fitness
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Proform 560hr Treadmill Walking Belt Logo
111 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
