Question about Sony Televison & Video
Srs blue light in lower right hand corner - Sony Televison & Video
Luvlee
  • 59 Answers
SOURCE: Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Posted on Mar 23, 2008
mistersony
  • 320 Answers
SOURCE: blue haze consuming my sony grand wega
It is definitely a bad optical block. Sony was offering an optical block replacement under warranty until June of this year, but it has ended now. Ballpark estimate is $700 to $1000 to have the optical block replaced.
Posted on Oct 19, 2008
waynejamescm
  • 67 Answers
SOURCE: Yellow Tint in Lower Right Corner of Sony KDS-R60XBR1 TV Screen
What you probably have is a very well known problem with the optical block. As it covers the screen, it will turn everything else greenish/yellow.
The optical block is very commonly replaced and an expensive repair, but the extended warranty (in place for all these TV's regardless of purchase date) on these sets is expired or about to expire. I would urge you to call Sony (1.800.222.SONY) immediately to try to get assistance, and to see if the warranty is up on it.
Hope this helps you...
Posted on Jan 05, 2009
greg_margo
  • 1959 Answers
SOURCE: Convergence is off in the lower right and upper left corner
The repair isn't too complicated if you're comfortable working with a soldering iron. Sounds like one of the "guns" is shot. The chips that need replacing are attached to the heatsink on the convergence board. The reason for replacing both chips is if you're going to bother to take the board out and replace one bad chip, that is the best time to replace the other older chip. The link below is to step by step instructions including pictures of the repair. You can check it out to see if you want to try it. If not, the repair is expensive (between 250-400) depending on the repairman. Best of luck with your convergence problem.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on May 23, 2009
rustym62
  • 201 Answers
SOURCE: sony wega kdf55 has blue spot in lower right
That is a symptom of the light engine failing. that is the projector part of your TV where the lamp plugs in. Go to Sony's website to contact them and see if your model is still under extended warranty, if so they will help set up repair. If not it could cost several hundred dollars just for the engine plus labor. Good luck
Posted on Feb 06, 2010
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
DVD player dont work
The fuse for this is in the block under the hood. In the lower right hand corner a blue 15 amp fuse marked "info" . (check under the lid of the fuse box)
Jan 25, 2014 | 2004 Chevrolet Silverado 1500 Crew Cab
Have a blue box in lower right hand corner of screen
i bet thats the lan icon if you have it blue and blinking its means good internet connection and your connected if that box has a red "X" on it its nit connected. theres nothing to worry.
Jan 20, 2011 | Computers & Internet
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Battery was low and put in new battery,problem SRC Light stays on how can I reset the SRC light?
I'm guessing you mean the SRS light, yes. When you have a bad battery the battery voltage can drop below 10 volts. The SRS unit detects this voltage loss and set a DTC (diagnostic trouble code) for an internal SRS unit failure. You have to erase the DTC memory. You'll need an SCS service connector tool (P/N 07PAZ-0010100) You can order one from your local honda dealer. Don't worry its not more than $10. Then you'll have to find the MES 2pin connector located in the upper right hand corner of the drivers underdash fuse box. It can be gray, green or yellow in color. 1.)Turn the ignition switch off. 2.)Unplug the MES connector from the fuse box and plug your SCS special tool into the MES connector. 3.) Turn the ignition switch on. 4.) The (red) SRS light in the dash will come on for 6 seconds and then go off. Remove the SCS tool from the MES (2P) connector within 4 sec. after the SRS light went off. 5.) The SRS light comes on again. Reconnect the SCS tool to the MES (2P) connector within 4 seconds after the SRS light came on. 6.) The SRS light goes off. Remove the SCS tool from the MES (2P) connector within 4 sec. 7.) The SRS light indicates that the memory is erased by blinking twice. 8.) Turn the ignition switch off and wait ten seconds. You may have to do this procedure a few time to get the steps correct. If this sounds to complicated I'm sure your local Honda dealer would be happy to reset the light for you for no charge. Just let them know that the battery was recently replaced and you think that the SRS light came on due to low battery voltage. -Hope this helps:)
Jan 13, 2010 | 1997 Honda Civic
My picture has been getting a blue area in the lower right hand corner of the screen and it is getting bigger farther along the bottom and the right side, also noticed a ring or outline of a circle when...
It is light engine that is going bad and causing blue haze/ clouds etc.
It is an expensive part, and I would recommend a new TV instead of its repair.
Thanks.
Sep 08, 2009 | Hitachi 50VF820 Projection TV
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
How to use blue usb mic
It depends on your operating system, but in XP, open Cubase. Go to the audio input settings, and be sure to select "USB Audio Codec" or "USB Audio Microphone" as the input device.
In Vista, right click on the speaker icon in the taskbar (usually lower right hand corner of the screen) and select "Recording Devices". Make sure to select the "USB Audio" device, then try Cubase again.
Dec 25, 2007 | Blue Microphones Ball Professional...
Convergence
Replace convergence IC's.
RE-check alignment
Oct 23, 2007 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
