Question about Tablets & eReaders
Tablet will not charge - Tablets & eReaders
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
Feb 06, 2016 | Hipstreet Flare 2 9 inch Tablet with 8GB...
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Battery will not charge
it means that something is wrong with your battery or its charger
Feb 02, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Tablets & eReaders Logo
83 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
