Question about Garden
Not starting in cold - Garden
I have a 2000 gmc it starts when it's warm but when it's gets cold have trouble start not the batter if I crank it over then trun the key of then try again it start find
Posted on Nov 17, 2014
The car starts easy when hot but when cold it takes long to start, what can be the course?
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
Won't start easily since it got cold (32degrees). It's fine once it starts
These will help.
Thanks.
Dec 14, 2012 | 2004 Dodge Ram 3500 Truck
Toyota rav4 diesel starting problems from cold it take a long time to start up when i leve it over night..
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Ford escort 55 van cold start problem 1.8 diesel 2001
COLD START PROBLEM
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Cold start is delayed, but starts
The cold start switch might be bad, not allowing the cold start injector to fire when the vehicle is cold, causing a longer than usual cold cranking time.. Have that switch checked.
Oct 20, 2010 | 2005 Nissan Quest
Car will not start when cold - otherwsie runs perfectly - put in new spark plus still does not help
It is not starting when cold since the cold start valve is not functioning. 1-It could be a coolant temperature sensor gives a wrong resistance readings when it cold so ECM doesn't know to send a signal to turn on the cold start valve. 2- It could be a bad cold start valve. I doesn't open even the ECM send a signal to it to open. You can see that Ohm reading on the terminals of the cold start valve is good, but it is still bad since your measuring the coil to open a valve showing the coil is good but valve gets stuck could not be opened. Good luck in checking these out for a good replacement..
Nov 14, 2009 | 2005 Subaru Forester
I just bought a 1986 fiero 2.8 v6 when i start the car it run about 5,000 rpms and will not come down to an idle
Check the EGR tube that bolts to the bottom of the upper intake (close to the throttle body) to the EGR Valve for cracks. Also check for Vacuum leaks. Also have the cold start system check for problems. The COLD START INJECTOR SWITCH might be bad.(The cold start injector switch activates the cold start injector on all V-6 Fieros. This switch turns on the cold start injector on initial start up to get the engine to start quicker and run smoother when it is cold.)
Jul 30, 2008 | 1986 Pontiac Fiero
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
