Question about ViewSonic OptiQuest Monitor
Blank screen connet an optiquest q171wb to a computer, it displays a white blank screen and all buttons don't function.
    Sergeant:
    Champion:
  • 225 Answers
Probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
Posted on May 25, 2009
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor is blank
HI there,
Problem : no power
Action : * Make sure power button or switch is ON.
* Make sure A/C power cord is securely connected to the LCD display.
* :Plug another electrical device (like radio) into the power outlet to verify that the outlet is supplying proper voltage.
Problem : Power is ON but no screen image.
Action : * Make sure the video cable supplied with the LCD display is tightly secured to the video output port on the back of the computer. If the other end of the video cable is not attached permanently to the LCD display, tightly secure it to the LCD display.
* Adjust brightness and contrast.
* If you are using an Macintosh older than G3, you need a Machintosh adapter.
Hope this helps.
Have a goo day.
Dec 08, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Blank white screen
Now reinstall the OS of the device connecting with desktop manager,before reinstalling take a backup and after the installation do the hard reboot.
Aug 05, 2009 | RIM BlackBerry Bold 9000 Smartphone
My screen is on but its blank the display light shows its on but i c nothing
which monitor do you connect to PC? has it worked togehter already?
please check if monitor is connected to graphic card of PC,
if yes and still same result after reboot, wire it up to another PC-tower, to doublecheck it is not broken..
if it's a laptop you are using and the internal display is malfunctioning you may be in trouble...
(see a technician, then
good luck)
Jun 18, 2009 | ViewSonic OptiQuest Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
BRAND NEW BUT NO DISPLAY
I also had the white screen / blank screen problem on my Inno today.  I powered the unit off, removed it from the home cradle, and then popped out the battery for about 15 seconds and put it back in.  This fixed the problem.
Sep 13, 2008 | Pioneer XM2go Inno Satellite Radio...
Blank white display on Nokia 3230
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
Sep 03, 2007 | Nokia 3230
Computers & Internet Logo
175 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
