Question about Proform 6.0 CE Rear Drive Elliptical Trainer
Tension will not adjust - Proform 6.0 CE Rear Drive Elliptical Trainer
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
How to adjust tension on bottom?
Usually, tension adjustments are made to the top. The bobbin tension is adjusted mainly only when using a different weight of thread (either very thin or very thick). Very seldom is the bobbin tension changed.
http://ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html
https://www.craftsy.com/blog/2015/03/how-to-adjust-sewing-machine-tension/
Nov 08, 2016 | Sewing Machines
The bobbin thread shows to the front. Does the bobbin or thread tension need adjusted
Generally, tension adjustments are made using the upper thread tension. Most likely the upper tension is set too tight and is pulling the bobbin thread up. Loosen the upper tension and try again. Tension is accurate when the upper thread and bobbin thread meet in the middle of the fabric. Whenever fabric, thread & needle are changed, there may be a need to adjust the upper tension.
HINT: When threading the upper thread, make sure the presser foot is RAISED during threading to make sure the upper tension disks are open and the thread seats properly.
Bobbin tension is only adjusted when the tensions are way out of whack. Only slight turns of the bobbin case tension screw are made in graduated movements and testing occurs after each adjustment.
Jan 20, 2016 | Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Model 1507 tension
I'm sorry, but you will have to be more specific. There is a top and bottom tension. The top tension is adjusted using a dial of some kind, visible on your machine. It has numbers on it; generally the lower the number, the tighter the tension. The bobbin tension generally does not need adjusting, although it can be adjusted. Please write again to let me know what it is doing that leads you to believe the tension needs adjusting.
Dec 11, 2013 | Singer 1507
I'm trying to change the belts for my 92 tercel but some how cant find the tension pulley. Can anyone please help me. I need to change both belts.
It appears that your car is equipped with multiple v-belts, rather than a serpentine belt so there most likely aren't tensioner pullies. Here is some general info that may help.
Alternator To adjust the tension of the alternator drive belt on older models, loosen the pivot and mounting bolts on the alternator. Using a wooden hammer handle, or a broomstick as a prying device, move the alternator one way or the other until the proper tension is achieved. Do not use a screwdriver or any other metal device such as a pry bar, as a lever. Newer models use a tension adjusting bolt. Loosen the pivot bolt and the locking bolt, then turn the tension adjusting bolt until proper tension is achieved. Tighten the bolts securely, run the engine about minute, stop the engine then recheck the belt tension. Air Conditioning Compressor A/C compressor (always use caution when working near the A/C compressor to avoid damaging the refrigerant lines) belt tension can be adjusted by turning the tension adjusting bolt which is located on the compressor tensioner bracket. Turn the bolt clockwise to tighten the belt and counterclockwise to loosen it. Air Pump To adjust the tension of the air pump drive belt, loosen the adjusting lever bolt and the pivot bolt. Move the pump in or out until the desired tension is reached. NOTE: The tension should be checked between the air pump and the crankshaft pulley on cars without air conditioning. On cars with A/C the tension should be checked between the compressor and the crankshaft pulley. Power Steering Pump Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup, similar to the alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt, then tighten the lock bolt.
Feb 12, 2011 | 1992 Toyota Tercel
1998 dodge neon airconditioning belt adjustment?
This procedure involves correcting the tension on the power steering accessory and A/C compressor drive belt.
1. Loosen the power steering pump locking bolts A and B and pivot bolt C(Illustration 1 and 2 ) to allow adjustment of belt tension.
2. Using a 1/2" breaker bar, adjust belt tension by applying torque to the square hole "D" on the power steering pivot bracket. Adjust the tension as follows:
Belt tension with no belt replacement: A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 100 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
Belt tension with belt replacement:
A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 135 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to 27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
C. Start the engine and allow the vehicle to idle for 15 minutes to allow the belt to seat.
D. Repeat the belt tensioning procedure, set belt tension to 135 lb.
click here for picture 1
click here for picture 2
Jun 13, 2008 | 1998 Dodge Neon
Proform 6.0 CE Rear Drive Elliptical Trainer Logo
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
