Question about ProDuplicator Computers & Internet
Target drive overflow error
The target dvd is large enough and yet we get the overflow error message
4 Suggested Answers
SOURCE: TARGET OVERFLOW ? / ARS-2030 LD COPY SMART PLUS
Your source dvd is most probably a 8.5Gb disc. You will need a blank 8.5Gb disc to copy to.Check out the size of the file on the source disc or the capacity of the source disc. If it is greater than 4.7 Gb.If you are using a 4.7gb to copy to,it will bring up an Overflow message.
Posted on Aug 12, 2008
SOURCE: teac 1x1 dvd duplicator dvw-d11
target drive not ready. what am I not doing right? it is a 1x1 dvd duplicator, teac. also had target overflow message what size dvd should I be using? new machine, copies cd great.
Posted on Oct 15, 2008
  • 3 Answers
SOURCE: Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Posted on Jun 14, 2011
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
Unsupported render target format
It sounds like your video card isn't powerful enough for the game (I would suspect). Re-post your system specs and what game you are trying to play and someone can look specifically at your system vs. the game requirements.
Dec 06, 2011 | Intel Computers & Internet
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
Target drive not ready
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
When i push copy on my DVD burner it says,Target Overflow,what do that means becouse it wont let me burn nothing its a[ TEAC 1 1 DVD/CD duplicator]
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank disc..it's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
Recommended:
Verbatim
SONY
Ritek
Ridata
May 08, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
"Source drive error" appears in the message window
I have Acard similar to CD1T07T0 CD-RW BURNER :
IT SAY " TARGET OVERFLOW" Why when I have enough capacity discs.
Jan 13, 2009 | Acard Technology (CD1TO7T) CD-RW Burner
Target Disc not Empty!!!
I have a DVD/CD duplcator, yes I can burn a CD, but when I try to burn a DVD I get this message TARGET DRIVE NOT READY, what can I do?
Nov 26, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Dec 23, 2007 | Acard Technology (ARS-2030LD) DVD±RW...
Computers & Internet Logo
Top ProDuplicator Computers & Internet Experts
David Payne
David Payne
Are you a ProDuplicator Computer and Internet Expert? Answer questions, earn points and help others
