Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Panasonic cinema vision hdtv 1080i - Panasonic PT-61LCX65 61" Rear Projection HDTV
SD Tech
  • 14553 Answers
SOURCE: panasonic hdtv 1080i all of the sudden has double
Go INTO the customer menu and select CONVERGENCE--what you are looking for is will blue or red not move in some direction?
If you find in your case blue OR red is wacked and will not adjust let me know--I can post here start to finish instructions for this repair on this set.....
You only need to be able to know how to solder and get at the chips--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you cannot do it yourself--let me know and I will give you options.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Posted on Nov 03, 2009
Testimonial: "Quick feedback with helpful questions."
ASE TECH
  • 57 Answers
SOURCE: We have blue lines or arches on the bottom and top
if you are handy with screw driver i suggest you remove all cd,dvd or anything you got on top of the unit and remove the back panel from this tv after you unplug the unit of course .first thing you want to do is clean your lenses most time dirt ,bugs,etc and other materials get logged on the lenses also make sure you dont spray directly any cleaning product on the lens make sure you spray a rag or some sort of cleaning towel.
after you finished doing this clean the front panel as well were screen is also clean the silver board thats in there as well.after you finish all of this replace all of the screws and boards back on and give it little while to dry off .turn it on see if u still have the lines if you do then your problem lies in the lenses they might be cracked.
if there not you might have bad electrode or power diode going bad.
Posted on Jan 09, 2010
Slinteriors
  • 8617 Answers
SOURCE: my panasonic cinema vision hdtv model # pt-47wx49
Does the power indicator blink? If so how many times does it blink?
Posted on Jul 29, 2010
Ecollier2012
  • 3459 Answers
SOURCE: I'm getting a green /
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 09, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic rear projection 52inch cinema vision
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Posted on Jun 06, 2012
Home cinema projector (panasonic) and blue ray player only show half an image
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Jun 26, 2014 | Panasonic PT-AE900U Multimedia Projector
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Jun 06, 2012 | Panasonic Televison & Video
I have a panisonic hdtv cinema vision 1080i the picture has a lot of red in it and kinda looks doubble? blurry? how can i fix this
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Panasonic Televison & Video
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Panasonic PT-53X54 53" Rear Projection...
My smasung hdtv 1080i is about 8-10 yrs old. it
you have a convergence problum. The convergence ics go bad about every 6 years
Apr 15, 2010 | Sony KP-53S65 53" Rear Projection...
We have blue lines or arches on the bottom and top of our screen of our Panasonic 53" hdtv 1080i Cinema Vision 2003.
Jan 09, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
