Question about Hardware & Accessories
Craftsman weedeater model # 358.796090
I was weedeating my back yard and it stop weedeating the motor turns when i lift it off the ground. it stops when i try to weedeated
how can i fix it
    Problem Solver:
  • 13 Answers
I would first clean the air filter, check fuel lines for cracks and check the fuel filter inside the tank, if those look good try adjusting then if necessary rebuilding the carburetor.
Also you might move your post to another section; it is under timers not trimmers. ;)
Posted on May 22, 2009
My weedeater worked one time and then it stop working not sure why it stoped i need to know how to fix it
well did you run straight gas or mixed fuel...
straight gas... throw it away and find another one
mixed... we need more info like how long it's sat ???
Aug 09, 2014 | Weedeater / Craftsman Igniton Module...
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Weedeater starts, then dies. Replaced the fuel line, spark plug, and carb...idols fine then stops
The symptom indicates a fuel delivery problem, which is usually the case...but I'm not so sure it is. I presume the fuel filter, air filter, and muffler are in good working order and the spark arrestor on the muffler isn't clogged with carbon. If this is an ignition issue, the machine would struggle to start and idle unless...
While idling is when the problem arises and it seems that the ignition may be shorting out at some point if there are no fuel delivery issues. You didn't say how long the machine would idle before stopping. Maybe check the small wire to the coil that goes to the ON/OFF switch for fraying and maybe grounding itself out while the machine is running/vibrating.This wire comes very close to the flywheel and normally has a female spade-connector on it, so check it's connection on the coil and at the switch. Check the flywheel to coil air gap also. Please post back if you find any of the above with issues.
Aug 12, 2010 | Craftsman 25cc Gas Line Trimmer
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
Weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Sep 06, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater quits working/button no longer activates weedeater
try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
Weedeater brand riding mower
Weedeater Rider mowers were made by American Yard Products you can contact them for a parts list
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Hardware & Accessories Logo
479 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
