Question about FreeMotion 330R Exercise Bike
How do I remove the right shield on a free motion 330R
How do I purchase a manual for my FreeMotion 330R ??
First, try Googling (FreeMotion)(330R)(manual) without parens.
May 30, 2017 | FreeMotion Exercise & Fitness
I have lost my power supply cord to my Freemotion 330R exercise bike. How can I get a replacement?
http://www.buyfitnessonline.com/cat alog/product
Pls order the cable from this site.
Oct 05, 2013 | FreeMotion 330R Exercise Bike
Belt falls off
see the next steps and fix it. God bless you
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Dec 18, 2012 | Schwinn 150 Upright Bike
Older proform crosstrainer ( recumbent bike ) just assembled from box and when I pedal grating sound from pedal area?
B) Lubricate your FITNESS BIKE. very important.
Sincerely. Mery Christmas.
Ernesto Cuadra
Managua, Nicaragua.
Dec 24, 2011 | Exercise & Fitness
Belt came off and need to put back on
SINCERELY. GOOD LUCK.
ERNESTO CUADRA
MANAGUA,NICARAGUA
Nov 25, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
How do I get a diagram to show me how to put a serpentine belt on a 1998 Ford Escort Station Wagon?
you ask here. Please rate highly
SECTION 303-05: Accessory Drive 1998 Escort/Tracer Workshop Manual
REMOVAL AND INSTALLATION Belt -2.0L SPI Removal
  1. Relieve the drive belt (8620) tension.
    • Use a (A) ratchet or breaker bar inserted in the square hole in the drive belt tensioner flange.
    • Rotate the (B) drive belt tensioner (6B209) in a clockwise motion to release belt tension.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the engine splash shield.
  1. Remove the drive belt from the accessory drive belt routing pulley (6C348) and then the remaining accessory pulleys.
Installation
  1. Position the drive belt over the accessory pulleys. Raise and support the vehicle if necessary; refer to Section 100-02 .
  1. Install the engine splash shield.
  1. Rotate the drive belt tensioner in a clockwise motion.
  1. Slip the drive belt under the belt idler pulley (8678) and release the tool. Remove the tool from the drive belt tensioner.
  1. Accessory Drive-With A/C
  1. Accessory Drive-Without A/C
Belt -2.0L Zetec Removal
  1. Raise the vehicle on a hoist; refer to Section 100-02 .
  1. Use a 13 mm wrench to rotate the drive belt tensioner (6B209) in a clockwise motion.
  1. Remove the drive belt (8620).
Installation
  1. Position the drive belt on all the pulleys and the drive belt tensioner.
Item Part Number Description 1 10300 Generator 2 19A216 Drive Belt Idler Pulley 3 3D673 Power Steering Pump Pulley 4 8509 Water Pump Pulley 5 6B209 Drive Belt Tensioner 6 19703 A/C Compressor 7 6316 Crankshaft 8 19A216 Drive Belt Idler Pulley 9 8620 Accessory Drive Belt
  1. Install the drive belt and gently release the drive belt tensioner.
    • Run the engine for several minutes to seat the belt into the pulley grooves.
Jul 09, 2011 | Ford Escort Cars & Trucks
Distorted sound especially if it is being touched.
I don't know what the answer IS but this may be a dangerous situtation if it reacts to being touched by you. A missing power or signal ground could be involved. Don't ground your body while touching the unit until you resolve the problem.
Bad signal ground isn't really dangerous. Try reseating every RCA cable with a twisting motion.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Frequently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
May 13, 2011 | Sharp SX9580 Amplifier
Hi, I bought the AVR133 and JBL5.1 home theater system a couple of years back. Recently, the Video 1: right input is not working and I get a slight hum when I plug in an audio jack into the socket. Can...
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Freqquently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
Mar 06, 2011 | Harman Kardon AVR 130 Receiver
Where can i find a free diagram of where the alternator is located on a 1995 saturn sc1
The location can best be seen by reading the replacement procedures. It is well hidden behind the right front wheel's splash shield. If you plan on replacing it yourself; You'll have the instructions.
Disconnect the negative battery cable...Remove the serpentine drive belt, use a wrench on the tension pulley to remove belt...Raise and support the vehicle...Remove the right front wheel...Remove the right wheel splash shield; it is two parts...Remove the alternator dust shield; it is attached with one bolt and one clip...Remove the two sets of wires from the alternator; one has a clip to connect it to the alternator and one is bolted to the alternator; be very gentle with the bolted one so you do not break the plastic insulator (especially during re-installation)...remove the upper and lower attaching bolts from the alternator; the top boltis easyto get to from the top of the engine, the bolt is just below the power steering unit...remove alternator through the wheel well opening...To re-install follow the steps in reverse.
FixYaWIZ....saailer@att.net
Dec 09, 2009 | Saturn SC1 Cars & Trucks
Chain rattling sound right front
no it would not be the timing belt making a rattling noise it couldn possible be you heat shield around your break rotor it could be someting having to do with ur suspenion like a spring maybe what kind of rattling noise? or a regular heat shield but loose in that particular area
Mar 31, 2009 | 2005 Subaru Forester
FreeMotion 330R Exercise Bike Logo
69 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
