Question about Zhone (6218-I2-200) Router
ZHONE 6218 unable to connect
Am using a ZHONE 6218 ADSL Router and I use a FUJITSU Lifebook(B Series) when the WIFI is done i can see the SSID, but when i click to connect after sometimes it says "not found or out of range" all the other SSID does ask me to input the network key, but mine doesn't do so, but other at my plc are able to access internet via that connection even from their laptops and mobiles with WIFI.
there is no IP restriction or any MacID filtering. i tried so manythings.. hope someone would be of an help on this.
Thank you
Sinan
  • 590 Answers
Try to configure you router with WPA authendication. provide some encryption password,if asked. Then configure your lifebook with manual ip by wifi adapter ->network settings-> tcp/ip properties - > specify manual IP something like 192.168.1.2 Now try connecting to your router.It should ask for network key and will connect if key provided matches with the one configured.
Posted on Jul 29, 2009
rickatnight1
  • 72 Answers
SOURCE: zhone 6218 driver
The manufacturer won't have your installation CD because that process is exclusive to your ISP. Check your ISP's website to see if they release their setup software online or contact them to get the required CD.
Posted on May 13, 2008
SOURCE: zhone 6218
Zhone (6218-12-200) I have wifi encrypted to manage 4 passwords. I am having a problem entering 3 additional at 64-bit - keeping in mind each person would be assigned to individual access codes
Posted on Nov 11, 2008
  • 31 Answers
SOURCE: Mtu setting
maybe the manual of that router helps a bit:
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Posted on Jun 16, 2009
SOURCE: Need login and password for a Zhone router/modem
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
Posted on Dec 29, 2009
  • 825 Answers
SOURCE: Need to change the NAT setting on my Zhone 6218
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Posted on Jul 16, 2010
I have Zhone Router 6218-12 with qualitynet connection at my residence.I ve been using this router with kems for last 2 years and had no issues but as a week back i connected to qualitynet the signal seems...
When you search for available wifi connections, do you find several routers? Other routers could be taking your bandwidth. There is a 802.11 protocol which establishes what channels routers can take, but this can be hacked, If you're in an apartment building, you may have this issue. Connecting by cable will fix it.
Nov 27, 2017 | Zhone (6218-I2-200) Router
How to turn zhone 6218-i2 router to wireless, now am using cable?
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
Zhone 6218 I2 User Manual
Nov 21, 2017 | Zhone (6218-I2-200) Router
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
Username & password
yes you can change the ssid
do to device then select adminstrator then change it username and password
Jul 15, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Username & password
Changing the router password from admin to any password I think that you would be possible. Other brands of router has that option. And the router password won't affect the password for the wireless connection, they are different from each other. Wireless mac Filter is another way of securing your wireless network. Its done by listing the MAC Addrses (media Access control) or the physical address of your wireless adapter on your computer/s to either allow them to connect to the network or not to connect to the network. but I recommend to just use WPA security. It's secured and its much easier to add another wireless device to your network, because you just need to put the password and no need to get the MAC address and manually encode in on your router setup page. Its also possible to change the SSID or the name of your network.
I will get back to you with the steps on how to change the ssid adn change the router password. Okay?
May 26, 2008 | Zhone (6218-I2-200) Router
Zhone 6218 driver
Apr 15, 2008 | Zhone (6218-I2-200) Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Zhone (6218-I2-200) Router Logo
399 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
