Question about Premiere Ranges P36G Gas Kitchen Range
Left oven hinges spring popped out of ****. repair person replace hinge pair and the hinge came loose from spring. can this hinge be replaced. the middle of the case holding hinge spreads apart
Left oven hinge has been sticking for a year. spray with pam and works for awhile. Hinge was really stuck...pulled oven door open and spring broke from hinge and bottom of it came out through the small **** with roller. called for repair. New hinge pair installed. two days later the hinge had come loose from the spring. Was the replacement hinge installed correctly. No way to access the **** except to slip spring into the hole..how can you repair this if you can not see what is going on in this small **** where the spring is slipped in.. When spring case is removed the middle of the case is spread apart???
    Top Expert:
  • Premier Master
  • 51,187 Answers
Call that repair person back as he did something wrong and should make it right .
Posted on Apr 16, 2015
2 Suggested Answers
SOURCE: Door hinge seems to be magnetic but can't get
The magnets on the door hinges and the ones on the inside of the oven must perfectly line up. If having problem getting hinge to fully extend, plug back with wadded up cardboard piece and shift door around until feel pull from magnets. Door should reset itself once magnets connect.
My door was installed off center and so the magnets are tilted. When I figured this out, it was a breeze.
Posted on Aug 26, 2009
Dacor
chk the spring and the door hinge. it is probably the hinge-spring that is broke, or slipped out of the hinge. lol.
Apr 27, 2014 | Dacor ECS130 Epicure Electric Single Oven
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
Feb 01, 2013 | Kenmore Ovens
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Replacing the oven door to the Whirlpool electric range RF375PXE
There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
Jan 31, 2009 | Whirlpool Kitchen Ranges
I lifted it by its door and its came off, not broke though
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 09, 2008 | Gaggenau EB388 Electric Single Oven
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Premiere Ranges P36G Gas Kitchen Range Logo
178 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
