Question about Confidence Power Plus Motorized Electric Treadmill
I have lost the safety magnet and it's in safe mode will it still work
Can i over ride the magnetic safety key
Its a safety switch. If you are sure that your would be safe without it. the you can short the leads of safety switch. Or you can use a small magnet to activate switch externally.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 24, 2016 | Exercise & Fitness
Lost magnet treadmill
Hello. In the mean time you can use a fridge magnet to get you back on the machine. You might need a strong magnet, so if the first one doesn't work keep trying.
try googling the brand of machine you have to purchase parts or try eBay under treadmill safety keys.
GymWorld.net.au
Jan 10, 2014 | Exercise & Fitness
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Treadmill will not start - say "Safe" on the Monitor
I'm not overly familiar with the Landice treadmills, although it sounds like it's not registering the safety key. Usually either a magnetic key or a slide key. Make sure your safety key is making good contact and if it's a magnetic key, that there's actually a magnet in it (sometimes they fall out without anyone noticing). If it's a key that you slide in to activate, see if there's any play in the port when you put the key in (wiggle it around) and if that works, the contact switch is slightly out of place. If the magnet is present and it's still not registering, either the reed switch inside the console has shifted and is too far away from the key magnet or it's malfunctioning (broken reed, shorted wire etc.)
Jun 01, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Jan 29, 2009 | Exercise & Fitness
Confidence Power Plus Motorized Electric Treadmill Logo
81 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
