Question about Arrow Tools & Hardware - Others
How to load a Arrow HT50iR.E.D. Stapler - Arrow Tools & Hardware - Others
5 Suggested Answers
  • 9 Answers
SOURCE: My friend let me borrow
Most arrow staplers have slide levers along the sides toward the front. Pull back on these and it should pop open. Some however load from the rear of the stapler. You push in and down on a square metal piece and it will unlock and than you pull it out toward you. slide in a rack of staples, put it in, relock and ready to go. If you put in too many staples it wont go all the way in to re lock.
Posted on Dec 02, 2008
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
  • 27 Answers
SOURCE: I don't know how to load staples into the Arrow
there should be a spring loaded clip at the end of the stapler opposite from where the staples come out push it in to release
Posted on May 29, 2010
SOURCE: how do I load JT21
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Posted on Aug 30, 2012
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
How do I load JT21 staples into a Arrow JT27 Stapler gun?
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
Cant get staples into it!!!
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Aug 19, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
I don't know how to load staples into the Arrow T55 manual power stapler
May 27, 2010 | Aerobie Arrow Fastener T55C All Chrome...
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
My jt 21m stapler is jammed and i cant get it to open
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Firing Blanks
No it is not operator error. This is the worst stapler made. I had one, it did the same thing, I brought it back and bought an arrow stapler, works great.
Jun 23, 2009 | Black & Decker 5700 Powershot Forward...
My friend let me borrow an Arrow HT50P Stapler and I would like to know how to open the stapler so I can load it
Dec 02, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
18 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
