Question about Dell Axim X5 Pocket PC
Can't connect to internet if it is not synced to computer....help please
I have synced computer with X5, I have the wireless card. I can get online when It is synced to computer but if I unhook it from computer then I can not get on internet with it. What do I need to do to get the X5 to connect to the internet without being synced to the computer. I got this so I could get online away from computer...Help please.
  • 35 Answers
The x5 is a little picky about it's wireless card and connectivity. Some wireless cards work better with the x5 than others. You might want to check that you have the latest device drivers for the card available and installed. Go through the connections on the x5. Usually should be set to internet or work.
I have an Ambicom card and used several drivers for it including Prism. It was never consistant and usually failed to connect
Posted on Aug 17, 2009
I can connect to internet when it is connected to computer through usb cord, I can sit in same spot next to computer and unhook usb and it will not connect to internet. This is less the 2 feet from the wireless router.
Posted on Jul 05, 2009
    Problem Solver:
  • 18 Answers
This unit works on WiFi so will only connect to the internet when in close range to a wireless router. Make sure your wireless card is connected properly and is actually sending out a signal. Go to "control pannel" then "network connections" and see if the connection is good. You can reconfigure your wireless network by going to "control panel" then "wireless network setup wizard" Good luck!
Internet and Bluetooth Problems
The issue you have is that the Axim does not have any built in connectivity for networking. In order for the Bluetooth to connect you, you would have to first pair the Axim to a Bluetooth enabled phone that can support Internet connections. Bluetooth on its own can't connect to the Internet, it is a protocol to link devices together.
The easier way would be to buy a wireless 802.11 compact flash card that will support PocketPC and then use a wireless access point to connect to the Internet.
May 11, 2009 | Dell Axim X5 PDA Snap-On Thumb Keyboard...
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
Have a dell axim x5 . how do you transfer files from the pc to ax
For exact to the point instructions we need specifics about what you want to do and with what but here goes...
Can't really help with the connect to the internet without more info than you provided. You need a wireless card, access to a wireless system and the drivers for the card. Even then it is not always consistant.
First I'm assuming you know that you need and have installed Activesync on the computer.
To transfer files to the Axim you simply drop them in the mobile my documents folder that is installed on the desktop when sync files is selected in Activesync. If you don't have it, open Activesync and select" options", check the "files" box. A desktop icon will be added.
If you mean install program files... most of the time you install on the desktop and it adds files to the x5 when you sync.
Sometimes you may need to transfer CAB files to the x5. In that case you will drag and drop the file on your x5 in my computer or on the icon on the desktop just like any other file move to another location
If your trying to sync with the wireless card, I am not familier with the method but in order to get the card to work it needs drivers that must be installed from the computer and through Activesync by wired connection first
May 03, 2009 | Dell Axim X5 Pocket PC
I have a dell axim x5 and it connects to my pc and internet fine when its on the docking station. I just need it to connect to my wireless internet connection wirelessly....
The X5 does NOT have wireless built in. You must add a wireless card (compactflash or SD) They tend to be finicky so do a little research for one that works well with the X5 first before buying.
Apr 08, 2009 | Dell Axim X5 Pocket PC
Setting up a computer as a wireless internet router
for windows xp you man set up the connection via cable or bluetooth and ms active sync - the htc (windows mobile) is able to use the hosts network connection.
you may also set up an ad-hoc wlan on you eee and turn on internet connection sharing for your mobile broadband connection. if you connect your eee to the ad-hoc wlan it should be able to access the internet
Mar 20, 2009 | ASUS Eee Box EBXB202-BLK-E0002 Intel Atom...
Cant find the switch on my laptop to make me wireless
I can't find any info about that laptop on the internet. If you have xp, go to start menu, control panel, network connections and see if you have a wireless internet connection in there. If not, you do not have a wireless card in your laptop. If you do have that connection, right click to enable it.
Please rate, thanks!
Mar 16, 2009 | Evesham Voyager 5700 Notebook
Dell axim x5 1180 truemobile wireless issues
Only WEP is supported------- also download the rom patch for this card off of the Dell site.
Oct 04, 2007 | Dell Axim X5 Pocket PC
Internet connection
For x5, you will need either cf wifi card or sd wifi card. If wifi network hotspot is free and internet access is allowed (check with your college's network administrator for information), all you need is be in the range, turn the wifi on and connect to it (there maybe several security settings you have to do on the axim and these can also be obtained from network admin). For paid hotspot, you will be redirected to enter username and password when you ty to access internet.
Sep 19, 2005 | Dell Axim X5 Pocket PC
AXIM X5
To copy word documents, simply connect your device to your computer, click "Explorer" in ActiveSync, and then transfer the word document from your desktop to your Pocket PC. ActiveSync will do the conversion from Word to Pocket Word for you. As for wireless internet service, you need a wireless Compact Flash card and data service. Sprint is one of the few companies that offers this, and there is also the Pocket Spider from Enfora which can connect on some wireless networks.
Sep 14, 2005 | Dell Axim X5 Pocket PC
WiFi Cards and Dell
They allow you to use your PDA on a wireless internet network.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
603 people viewed this question
Alun Cox
