Question about Kenmore 54501 Dehumidifier
Dehumidifier has power but neither the fan nor the compressor will pull in.
Kenmore dehimidifier has power, fuse is good, transformer has a good 120volt primary and a 13volt secondary but unit will not run.
  • 11 Answers
It might be the thermolink on the fan motor.
Posted on May 29, 2009
Kenmore 34351 dehumidifier compressor does not work. fan works on hi and low, fuse is good. what could be the most likely cause?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 01, 2011 | Kenmore 54351 Dehumidifier
Fan runs, compressor switch seems to click but fails to start. Compressor is warn to the touch.
The compressor is not starting, either the start components (relay and capacitor) have failed or the compressor is no good.
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
heatman101
May 24, 2011 | Kenmore 54501 Dehumidifier
I have a Kenmore 54701 Dehumidifer that quit working is there any thing to look for or just throw it out and buy a new one
Is it not powering at all? Remove cabinet and check glass fuse on power supply board
Is it running but no water?
Check to see if fan is blowing; if not then thermosenser on fan motor blown
Fan and compressor running but no water? Maybe the room is already dry; if not than probably have coolant leak - not worth fixing
Dec 04, 2009 | Kenmore 54701 Dehumidifier
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Sep 01, 2009 | LG DH30 GoldStar Dehumidifier
Kenmore 54701 (70 pt) dehumidifier is not prerforming properly
could be a bad humidistat or a bad PTC relay on the compressor, check for voltage going to compressor, and check neutral continuity, if there is both then you have a bad compressor, check warranty on comp replacement, if no voltage then the humidistat is probably bad
Jun 13, 2009 | Kenmore 54701 Dehumidifier
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Aug 18, 2008 | Kenmore 54701 Dehumidifier
Kenmore 54501 Dehumidifier Problem
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Dehumidifier not dehumidifying ...
Save the old one for parts if you get the same new one but I def. don't reccomend buying this unit again. The reviews are bad. The fan is not covered under the warranty except first year or extented warranty. I spoke with Kenmore & Sears about this to see if coverd under 5 yr. Only compressor,tubing & refrigeration system(see inside of front cover for warranty info.)
Sound more like a sensor/circuit board problem to me since fan is turning. I think the signal determins which setting fan needs via sensor assembly to run. I could be wrong. Justa thought.
Can you def. hear the compressor come on. You can look through grill to see fan spin & the compressor makes a clank/clunking noise/ The fan & compressor should turn same time. Good luck! If you got any info. on my fan problem & you have update or fixed your problem I ccould use some help. Check post for my problem.. Thanks! panfan1
Aug 13, 2007 | Kenmore 54701 Dehumidifier
Kenmore 54501 Dehumidifier Logo
302 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
