Question about Krups Aroma Control 229 Coffee Maker
Opening the coffee basket - Krups Aroma Control 229 Coffee Maker
Need a manual for JWX27
You can find the manual for this coffeemaker directly at the following link (for as long as it lasts): http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1414150683537/documents/instruction-manuals/JWX27_43_56431310.PDF
With this coffeemaker, you can brew with the cover open. I recommend observing a brew cycle to see if the coffee with floating grounds are overflowing the filter into the strainer basket. If this is the case, inspect the strainer basket's valve to make sure it is not blocked and working properly. Also make sure the pot is fully in place so that the lid aligns properly with the strainer basket to open the valve adequately. Otherwise, the filter and/or the coffee grounds are too fine. I recommend a permanent filter basket (around $5) and course-ground coffee. Both will add to better tasting coffee.
Oct 08, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart coffee maker from costco, the grinds backed up twice.
It sounds like the release at the bottom of the basket was not open when you put the pot in to receive the coffee. You might check the release on the basket by takin the basket out, putting water in the basket and tripping (pushing up) on the botton on the bottom to see if the water flows through. It could be clogged.
You should clean the coffee maker about every 30 pots of coffee to keep scale from gathering in the heating tubes.
May 19, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Filter basket wont open..is there a secret?
You have to pull it open from the side. Then, lift out the filter and the basket.
Aug 09, 2008 | DeLonghi DC110T Coffee Maker
Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
Dec 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Krups Aroma Control 229 Coffee Maker Logo
21 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
