What do I use cassette deck for on bauhn mini hi fi system
Benimur
  • 6966 Answers
SOURCE: no sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 16, 2008
SOURCE: MV530i Mini DV
clean the head
Posted on Mar 18, 2008
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Posted on Oct 24, 2008
  • 263 Answers
SOURCE: no connecting wires..????
They seem to have special leads to connect them together pretty expensive ....
http://cgi.ebay.co.uk/KENWOOD-B-B5-Connector-Hi-Fi-component-cables-lead_W0QQitemZ120453267078QQcmdZViewItemQQptZUK_AudioTVElectronics_HomeAudioHiFi_Tuners?hash=item1c0b92fe86&_trksid=p3286.c0.m14
Posted on Aug 03, 2009
pabloloco
  • 2335 Answers
SOURCE: I need the code for a Teac CD-X10i mini hi fi
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Posted on Apr 27, 2010
Sony stereo
Check speaker wiring on the back for shorts, if okay! the problem is in the audio output ic in the unit.
Apr 22, 2012 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
We need a manual of Sony mini hi-fi component system mhc-5600
The manual that you are looking for can be downloaded here http://www.nodevice.com/manual/sonymans/manual2435pdf/get3955.html In order to view the PDF file you will need to have Adobe Reader installed. This is provided free from their website, http://get.adobe.com/uk/reader/ djrydr.pngThis would be the first page from the manual. Hope this helps, and good luck DJRYDR
Jul 27, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
When i turn on the power it cuts off&the red light startes to blink
there are so many reasons for this matter.better to contact qualified service Technician
Jun 14, 2011 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
CD burned on my computer won't play back on my Sony Mini Hi-Fi Component System MHC-NX1. I'm using Memorex Music CD-R and the burned CD will play back on my other stereo systems.
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Nov 27, 2010 | Sony 720W 5-Disc Mini Hi-Fi Component...
I turn the stereo on and it turns off and then the power button starts blinking
i turn the stereo on and it turns off and then the power button starts blinking
Sep 04, 2010 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
16 people viewed this question
 Grubhead
Grubhead
