Question about Compaq Presario 5000 PC Desktop
Screen is black and then says check memory modules, then goes black again
I have a compaq persario 5000, and when I turn it on I have a black screen then it says check memory modules and something about failed, but it flash so quickly I can't read it before it goes black. Can you help me?
    Genius:
  • 1,605 Answers
Turn off the machine, open the case and take out the memories stick. make sure the contact on the stack and the slot on the motherboard are dust free. reinsert the memories and turn on the machine.
Posted on May 21, 2009
Compaq Presario F572us will not stay powered up. It starts and then screen goes black and shuts down. When I press the power button again it lights up but the computer powers off again.
Here's what you can try.
1. Remove the battery and try turning the laptop just from AC adapter. Maybe the battery is bad and shorting the system.
2. Try turning it on just on battery power (with AC adapter removed). Maybe the AC adapter is bad and shorting the system.
3. Try removing memory modules one by one. Maybe your failure somehow related to memory. Test the laptop with only one memory module installed. Try either one.
If nothing helps, the laptop still turns on and off by itself, most likely this is motherboard related failure.
Jan 19, 2011 | Compaq Presario F572US Notebook PC
Hi, I have a HP Persario CQ60 Laptop. W hen i switch it on, the power putton and wifi light up, the little power light turns on and i hear the CD rom drive for a couple of seconds but nothng else hhappens...
mines does the same but wen u here it start up an the screen goes blank take the battery out then it will say start windows normaly or safe and safe made networking click on safe mode networking and u can use your laptop again but with no sound hope this helped
Nov 18, 2010 | Compaq Presario CQ60-220US PC Laptop
My compaq presario 5000 does not see the new memory and when i put in both 256 cards it won't boot up just a black screen
this might be incompatibility issue with the memory and pc. check for system specs from compaq and check also for maximum memory capacity.
Mar 29, 2010 | Compaq Presario 5000 PC Desktop
Light goes on and it beeps a long beep thats all
Open your cpu cabinet .
Refix RAM memory.
Pull cmos cell for 15 minutes then refix it then check.
Reattach all connection to motherbord chip set like atx power supply.
Open processor fan then open processor then clean it and refix it.then check.
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 19, 2009 | Compaq Presario 5000 PC Desktop
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Hp nx 5000 - memory problem
The memory modules are located at the bottom of the laptop under one of the panels.
The memory modules may be OK and may only need reseating. Then boot up the laptop to see if it works, if it doesn't work, the memory may be faulty, take it to a computer shop to get it tested.
Apr 07, 2009 | HP Compaq nx5000 Notebook
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Blue screen error message, computer will not boot up
Check your ram. You may have a bad memory module. If you reinstalled your operating system on a different hard drive, then it sounds like it may be your memory. Turn the computer off, remove and reinsert the memory. Turn computer back on. If this does not work. Remove on of the memory modules and see how that works. Then if that doesn't work, remove the other memory module and plug the other one back in. Be sure the memory is seated properly. Always have the power off when doing this.
Feb 26, 2009 | HP Compaq Presario SR2150NX PC Desktop
Compaq Presario 5000 start up problem
Follow the instructions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=96382&prodTypeId=12454&prodSeriesId=96382&objectID=bph07173
Nov 11, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
