Television signal problems - Televison & Video
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
Signal Problems
firmware needs to be upgraded call samsung and they will sent it to you
Apr 27, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
No signal and theres signal
sounds like you need a new tuner replaced or the ssb(small signal board) inspected. The tuner recieves the cable signal and converts it into an intermidiate signal which in turn the ssb processes into audio and video signal.
Sep 09, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
Autoprogram for lcd hd tv keeps taking me back to autoprogram.
You may need a signal amplifier to get the signal strength to keep the television synchronized with the input signal. The television tuner is losing the signal and has to keep searching to find it. You can amplify the signal with a small cable signal amplifier.You can usually find these amplifiers in your local electronics store like Fry's or the Micro Center. They are adaptors that will hook up between the cable and the television input. Look for them under television cable signal amplifiers. You can also buy them on line. Just put the name in you favorite search engine and find the stores that sell them. If you are still in doubt about the amplifier. Make a call to the local or online store and ask them how they work and how to use them with you television. They will be glad to help you and make a sale . If this doe not solve your problem then you may have a problem with the signal input circuit and need a service technician to test it. They will be able to tell if if you need some repairs to fix it. If you have more question about this problem just ask and some one will help you. I hope this information help you with your problem.
May 26, 2009 | Dynex DX-LCD37 TV
3 rooms with dish works on 2 on 3rd i get no sync
This problem could be caused by a weak signal amplifier in the tuner section of the Television. You can try putting the television in a location where it will receive a stronger signal from the Dish. Closer to the source of the signal. You can also try getting a signal amplifier to increase the signal strength to the television tuner.These amplifiers are usually sold at the local electronics stores like Fry's or the Micro Center. You can call the stores and ask them if they have signal amplifiers for cable and satellite signals. You can also find them on line by using the search engines looking for signal amplifiers for cable and satellite signals. If all this fails to solve your problem, Call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of you television and the problem you are having with the loss of signal reception. They should be able to tell you how to resolve the problem. The customer support website is www.insignia-products.com. you can use the customer support section here also to explain your problems. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Blue screen on 60in
You may have it on the wrong input channel to receive the television signal. You should check what input you have selected on you remote control.It should be set to television to receive the television. signal.If you are using another source to input the signal to you television check that remote and make sure it has the proper setting to watch the television. For help with your problem you can to the Sony website. www.sony.com and go to the support section and put in the model number of you television and check the frequently asked question and the troubleshooting sections to see this this problem has occured to someone else and has been answered. The service number for Sony televisions is 239-768-7547. I hope this helps you with your problem.
May 06, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Losing signal intermittently every 1-5 minutes
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Apr 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
